IVF8 and SciGraph
parubini
I have just upgraded to IVF8 from DVF6.1. My app uses SciGraph but I have problems compiling SciGraph. Will SciGraph compile with IVF8 ?
Steven_L_Intel1
Yes, but... If you converted a project from CVF, you should go into the project properties, Fortran, External Procedures and change the calling convention from CVF to Default. And this is necessary only because of a bug (being fixed) where ATTRIBUTES DEFAULT gets incorrectly overridden by /iface:cvf.
Once you do this, it should build fine - it did for me.
parubini
Thanks for the suggestion, unfortunately I had already noticed that from discussions in other threads, I am still getting the following error
Compiling...
ifort /nologo /include:"Release/" /fpscomp:nolibs /fpe:0 /module:"Release/" /object:"Release/" /libs:qwin /4Yportlib /c "D:Program FilesIntelFortranSCIGRAPHSgdata.f90"
ifort /nologo /include:"Release/" /fpscomp:nolibs /fpe:0 /module:"Release/" /object:"Release/" /libs:qwin /4Yportlib /c "D:Program FilesIntelFortranSCIGRAPHSglowlvl.f90"
fortcom: Fatal: There has been an internal compiler error (C0000005).
compilation aborted for D:Program FilesIntelFortranSCIGRAPHSglowlvl.f90 (code 1)
Which is not so helpful !
Steven_L_Intel1
Please download the latest update 8.0.038 - I used that and the SCIGRAPH sample from CVF built and ran fine.
parubini
Steve - I'm not having much luck here. I uninstalled my existing version and downloaded and reinstalled 8.0.038
"Intel Fortran Compiler Integration for Microsoft Visual Studio .NET 2003, Version 8.0.1877.2003"
But I am still getting the following error
ifort /nologo /Zi /Od /fpscomp:nolibs /fpe:0 /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /4Yportlib /libdir:noauto /c "D:Program FilesIntelFortranSCIGRAPHSGLOWLVL.F90"
compilation aborted for D:Program FilesIntelFortranSCIGRAPHSGLOWLVL.F90 (code 1)
Do you have any other suggestions ?
Phil.
Steven_L_Intel1
I can't reproduce the problem. Start a "Build Environment for Fortran IA-32 Applications" window and type:
ifort -what
what does it say?
sabalan
Let me guess: Scigraphs documentaion in Scigraph.wri in CVF issaying that you need (only) scigraph.mod on the path. But actually even sgadmin.mod, sgdata.mod, sgdraw.mod and sgplot.mod are needed on the path, otherwise you get "Internal compiler error" in CVF 6.6b. Maybe this is the case even in IVF 8?
Make your workspace to "see" all these .mod files and see what happens.
Correcting this documentation was thought to be "cosmetic"and not made in CVF 6.6c.
Sabalan.
Steven_L_Intel1
None of the samples were updated in 6.6C. Somehow I missed the significance of the internal compiler error if you don't have all the modules available - I'll take another look at that.
sabalan
Steve,
Internal compiler error is fixed in the first release of 6.6c, as I could see, and even some modifications have been done in Scigragh.wri, but the need to having all .mod-s available is not mentioned. I wrote exactly like this even in my previous message regarding the 6.6c update.
What has to be tested is if IVF 8 behaves the same as 6.6b when .mod-s are not available.
Sabalan.
Steven_L_Intel1
6.6C doesn't touch any of the samples. It is a compiler and libraries update only.
IVF should behave the same in this fashion as 6.6C - the fix was made in shared sources.
parubini
Steve
I checked my version thru' the cmd line and found my problem. I had uninstalled the previous version, and then reinstalled the same one. Uninstalling again and reinstalling 038 now gives
Intel Fortran Compiler for 32-bit applications, Version 8.0 Build 20031229Z
Package ID: w_fc_pc_8.0.038
And SciGraph now compiles ok.
Thanks for the assistance
Phil.
Steven_L_Intel1
Glad to hear it.
