29427 Discussions
Ifort 15.0.2 segfaults on shared pointer access within OpenMP tasks
Alfredo
I have a problem with OpenMP tasks in the Fortran code below:
program helloworld
  use omp_lib
  implicit none
  integer, pointer :: a(:)
  allocate(a(40))
  a = 0
  !$omp parallel shared(a)
  !$omp master
  call foo(a)
  write(*,*)'out'
  !$omp end master
  !$omp end parallel
  deallocate(a)
contains
  subroutine foo(a)
    use iso_c_binding
    integer :: i, omp_num
    do i=1,40
       !$omp task firstprivate(i)
       omp_num = omp_get_thread_num()
       write(*,*) "end", i,omp_num, a(1)
       if(omp_num.eq.1) a(1:40) = omp_num
       !$omp end task
    enddo
  end subroutine foo
end program helloworld
What happens is that the first task executed right after the "out" message is printed segfaults due to an invalid access to the a pointer. It seems that the a pointer passed to tasks goes out of scope when the master thread returns from the foo routine although it shouldn't since a is not a local variable of the foo routine. This code works in gfortran (4.6 and 4.9). Is this code OpenMP compliant or is it a problem in ifort ?
One workaround to this problem is to declare, within foo, a pointer p which points to a and to pass it to the tasks like this:
  subroutine foo(a)
    use iso_c_binding
    integer, pointer :: a(:), p(:)
    p => a
    do i=1,40
       !$omp task firstprivate(i) firstprivate(p)
       write(*,*) "end", i,omp_num, p(1)
       if(omp_num.eq.1) p(1:40) = omp_num
       !$omp end task
    enddo
  end subroutine foo
The firstprivate ensures that a private copy of p (i.e., the pointer, not the actual memory area) is passed to every task which prevents the data from going out of scope.
Can anyone help?
Alfredo
