Immediate window
anishtain4
What is the usage of immediate window? I'm using VS2008
isn't it for using function and subroutines while you are debugging? like VB? when I try to use simple MAXVAL it says: "Undefined variable maxval"!!! so practically it's not usable for ifort?
Correct - it's not usable for Fortran code.
joerg_kuthe
Sorry, I don't find that correct. I am using the Immediate Window quite often (while debugging).
For example you can enter a local variable's name and its current value is output. So, I am able to compare that value with a later one, which might be changed in a loop (so I don't have to write it down to track changes). You can also do calculations.
Just try and play
Jrg
