First the code. Througn judging a large number a prime, I test the OpenMP Parallel.
[fortran]
program main
use portlib
implicit none
integer :: i, j
integer :: x(10000) = 0 ! #1
integer :: a(10000) = (/(i,i=100000001,100010000)/)
real :: Elapsed_time
Elapsed_time = TIMEF()
!$omp parallel do
do i = 1, 10000
x(i) = is_prime(a(i))
end do
!$omp end parallel do
write(*,*) ' Elapsed_time = ', Elapsed_time
write(*,*) 'end'
contains
function is_prime(num) result(prime)
integer, intent(in) :: num
integer :: prime
integer :: i
prime = num
do i=2,int(num/2)
if(mod(num,i)==0) then
prime = 0
exit
end if
end do
end function is_prime
end program main
[/fortran]
Second, In line #1, now i initialize the x(10000) to 0, if i didn't do this, the result of x will be totally wrong, which you can see in the monitor. If I dellete all the OpenMP Directive and disable the setting in the proerties, even if i didn't initialize the x array ,the result will be correct.
I understand the share memory mechanism of the OpenMP, But i cannot understand these from this mechanism. Anyone can help me , thank you!
