Inconsistent Memory Reference
Blane_J_
Hi, I am doing some mixed programming between C++ and Fortran. A problem comes up about passing a character array from fortran to C++ as shown in the code. The memeory addresses before and after calling the subroutine are not consistant to each other thus the character array is not properly passed. Am I doing it the wrong way or is there anything I have not yet noticed ? Thanks for any help.
PS: The project was debugged on x64 platform.
FortranFan
I will suggest you employ the standard Fortran feature of interoperability with C: your C++ code for your DLL can remain unchanged, but you can try the following with your Fortran program:
module FModule
   use, intrinsic :: iso_c_binding, only : c_char
   implicit none
   interface
      subroutine testchararray(arr) bind(C, name="testchararray")
         import :: c_char
         implicit none
         character(kind=c_char,len=1), intent(in) :: arr(*)
      end subroutine testchararray
   end interface
end module FModule
program Main
   use, intrinsic :: iso_c_binding, only : c_char, c_loc, c_intptr_t
   use FModule, only : testchararray
   implicit none
   integer(c_intptr_t) :: adda
   character(kind=c_char,len=10), dimension(2) :: arr = ["1234567890", "0987654321"]
   write(*,"(z0)") transfer( source=c_loc(arr), mold=adda )
   call testchararray(arr)
end program Main
Look in Intel Fortran documentation for Fortran/C or any books/online resources on modern Fortran.
FortranFan
module FModule
   implicit none
   interface
         import :: c_char
         implicit none
   end interface
end module FModule
program Main
   implicit none
end program Main
Blane_J_
Thanks for your solution FortranFan.
