Incorrect Fortran code?
Marc__Jan
Following program crashes on Linux/x86_64/intel fortran (also gfortran & NAG fortran)
      program chk_trim
          CHARACTER*(30)  TAB
          TAB='RSRDATA_AAAAAA\0'
          call shady(tab)       !! 1st call does not seg fault
                                !! as TAB string is on the stack
          call shady('RSRDATA_BBBBBB\0') !! this seg faults
                                !! since string passed in argument
                                !!  is in non-writable memory region
          write(*,*) 'tab=',tab
      end program
      SUBROUTINE SHADY(TAB)
          CHARACTER*(16) TAB
          TAB  = TRIM(TAB) !! -- CRASHES HERE --
          write(*,*) '--## TAB=', TAB
      RETURN
      END
But surprisingly it does not crash on AIX xlf95 (PowerPC). Nevertheless, it looks like invalid Fortran code - is this right?
BR, Jan.
GVautier
New Contributor III
That's why interface and intent has been added to fortran. Before that, it was a common problem leading to crash or constant value change depending of compiler constant implementation.
