29616 Discussions
Incorrect behavior with inheritance when using submodules?
Christopher_H_1
I have a test program which I believe is producing correct answers when compiled with ifort Version 18.0.0.128 Build 20170811 and incorrect answers when compiled with the newer ifort Version 18.0.1.163 Build 20171018.  In both cases, the code compiles with no warnings or errors.
I believe the code is valid, although it is certainly possible I am misunderstanding how these features work.  The problem occurs when I use a submodule to separate the implementation from the interfaces, and I have a type which extends another, and both types have a procedure with the same name.  If I don't use a submodule, and put all declarations in the "contains" section, it works fine.  Here is a reproducer:
! Module Model
module Model
  implicit none
  private
  ! parent_model_type
  public :: parent_model_type
  type :: parent_model_type
    private
  contains
    procedure :: go
  end type parent_model_type
  ! child_model_type
  public :: child_model_type
  type, extends(parent_model_type) :: child_model_type
    private
  contains
    procedure :: go => go_child
  end type child_model_type
  interface
    module subroutine go_child(this)
      class(child_model_type) :: this
    end subroutine go_child
  end interface
contains
  ! go
  subroutine go(this)
    class(parent_model_type) :: this
    print *, "Parent model is going"
  end subroutine go
end module Model
! Submodule Child_Model
submodule(Model) Child_Model
  implicit none
contains
  ! go_child
    print *,"Child model is going"
end submodule Child_Model
! Program test
program Test
  use Model, only : parent_model_type, child_model_type
  implicit none
  type(parent_model_type) :: parent
  type(child_model_type)  :: child
  call parent%go()
  call child%go()
end program Test
When I run this code compiled with ifort Version 18.0.1.163 Build 20171018 I get the wrong answer:
$ ./test.exe
When I run this code compiled with ifort Version 18.0.0.128 Build 20170811 I get the correct answer:
$ ./test.exe
Is this a bug in the newer 18.1.163 compiler?  Or am I doing something wrong?
Thank you for your time,
Chris
FortranFan
Christopher H. wrote:
.. I believe the code is valid, ..
Is this a bug in the newer 18.1.163 compiler? ..
I agree your code is valid.  So I firmly believe this is a bug in update 1 to Intel Fortran compiler version 18.0, an unfortunate regression.
I suggest you submit an incident at the Intel Online Service Center (OSC):
https://supporttickets.intel.com/?lang=en-US
Christopher_H_1
Thank you very much for the quick feedback.  There is variation of this that produces a link error.  I think it's very closely related to what I submitted above.  If you have a child type that has a procedure which the parent does not have, the code won't link with version 18.0.1.163 Build 20171018:
! Module Model
module Model
  implicit none
  private
  ! parent_model_type
    private
  contains
  ! child1_model_type
  public :: child1_model_type
  type, extends(parent_model_type) :: child1_model_type
    private
  contains
    procedure :: go => go_child1
  end type child1_model_type
  interface
    module subroutine go_child1(this)
      class(child1_model_type) :: this
    end subroutine go_child1
  end interface
  ! child2_model_type
  public :: child2_model_type
  type, extends(parent_model_type) :: child2_model_type
    private
  contains
    procedure :: go => go_child2
  end type child2_model_type
  interface
    module subroutine go_child2(this)
      class(child2_model_type) :: this
    end subroutine go_child2
  end interface
contains
end module Model
! Submodule Child1_Model
submodule(Model) Child1_Model
  implicit none
contains
  ! go_child1
    print *,"Child1 model is going"
end submodule Child1_Model
! Submodule Child2_Model
submodule(Model) Child2_Model
  implicit none
contains
  ! go_child2
    print *,"Child2 model is going"
end submodule Child2_Model
! Program test
program Test
  use Model, only : child1_model_type, child2_model_type
  implicit none
  type(child1_model_type)  :: child1
  type(child2_model_type)  :: child2
  call child1%go()
  call child2%go()
end program Test
ifort version 18.0.1.163 Build 20171018 produces this link error:
$ make
ifort -g -traceback -O2 -o test.exe test.f90
/tmp/ifortDczkUi.o: In function `MAIN__':
/home/Christopher.W.Harrop/test/intel_bugs/bug_2/test.f90:117: undefined reference to `model_mp_go_'
/home/Christopher.W.Harrop/test/intel_bugs/bug_2/test.f90:118: undefined reference to `model_mp_go_'
ifort version 18.0.0.128 Build 20170811 builds and runs the code correctly:
$ make
$ ./test.exe
Although this is a very similar scenario, the behavior is a bit different.
FortranFan
@Christopher H.,
I suggest you include both the cases in your incident submission at the OSC or submit two different incidents to ensure the Intel Fortran team's attention to both the issues.
Btw your second case appears similar to this other issue reported with SUBMODULEs at the Windows forum:
https://software.intel.com/en-us/node/740567#new
Sitting afar I get the impression Intel Fortran team has major difficulties developing reliable test suites with adequate coverage of features introduced in the Fortran standard since the age-old Fortran 90/95 revision.  Their regression testing of new compiler versions suffers significantly as a result.  SUBMODULE facility that got added starting with Fortran 2008 is but one latest example of this casualty.
Christopher_H_1
Thank you again for helping verify I'm not going crazy.  Much appreciated.  I will proceed with reporting both cases.
Pelle_R_
I have similar problems with submodules using ifort 18.0.1 as well. Things compile and work just fine with 18.0. The amount and severity of regressions in the 2017 and 2018 versions is simply ridiculous.
Johannes_Rieke
New Contributor III
Hi same for me.
As FortranFan said a test case would have shown this. And my OSD filed ticket for an ICE error in PSXE2018 contains such a test case... (https://software.intel.com/en-us/node/740567). There are many more here, I suggest.
