29390 Discussions
Incorrect platform for Release configuration used by compiler
jirina
I am using Intel Compiler XE 2011, Update 2, and Visual C++ 2008 Professional, on Windows 7 Professional, 64-bit. The problem I have is following:
- If I select Debug configuration from the list in the Standard toolbar, the compiler takes into account also the selected platform (I have Win32 and x64).
- If I keep the Win32 platform and change the configuration to Release, the compiler does its job for Release x64 (I can see this in the window Output).
- The only way to compile Release Win32 is to use the menu item "Build - Batch Build..." and check the Release Win32 configuration.
Is there anything I can do to make the compiler take into account changes of the platform for the Release configuration?
The log suggests that it thinks it is building a Release X64 configuration. I know it may be annoying, but perhaps it would be best at this point to create a new project, add the sources and work from there.
This isn't the "compiler", but Visual Studio, and my guess is that you have not correctly added the x64 configuration. In the toolbar, there are separate dropdowns for Debug/Release and Win32/x64. Typically if you change the platform to x64, you can switch back and forth between Debug and Release without issue.
Please attach the .vfproj file for your project so that I can look at it.
jirina
I admit I might have done something wrong when adding the x64 configuration even though it looked easy and straightforward. My problem is that Visual Studio ignores the drop-down for the platform when Release is selected in the first drop-down - x64 it used when either Win32 or x64 are selected.
Attached is my project's .vfproj file, thank you for checking it.
You have a whole bunch of configurations in there - which ones are you using? I see one labeled "Release x64" which doesn't make a lot of sense to me. Can you show me a build log (buildlog.htm) with the wrong build type?
Did you make any changes in Tools > Options > Intel Visual Fortran > Compilers?
jirina
I use all of them for various purposes; however, I use Release and Debug, for both Win32 and x64 platforms, most frequently.
Indeed, I can see "Release x64" too in the file, even though it is not included in the correspoding drop-down. The question is whether this could be the cause of my problem and whether it can be manually removed from the project file.
I did not modify settings in Tools > Options > IVF > Compiler; they are the same since I installed Update 2.
My build logs are quite old files, so I deleted them, and I am not able to find in help or options how to enable generating buildlog.htm; am I overseeing something? It feels like buildlog.htm is not created (I created a completely new project and buildlog.htm does not get created, even though Build Log File parameter in General options is set to $(IntDir)\BuildLog.htm and $(IntDir) should be the value of the parameter Intermediate Directory, which is $(Configuration Name).
If you are building a Fortran project, there will always be a buildlog.htm in the configuration subfolder (Debug, Release, etc.)
jirina
I must then be doing something wrong - I checked the contents of corresponding subfolders and there is no buildlog.htm file. I can only see *.obj, *.res, mainfest-related files and the executable. I tried rebuilding and made sure the contents of the corresponding subfolder had been deleted; buildlog.htm not appearing.
I am sure buildlog.htm was created by Update 1, so something must have happened since the time I uninstalled Update 1 and installed Update 2, maybe Microsoft Updates to Visual Studio? Let me try reinstalling Update 2 if it helps - OK, it seemed not to help, but I found out that there is an option in Tools > Options > IVF > General to Generate build logs, and this option was not checked.
So, you can find attached the build log from the compilation and linking when Release and Win32 are selected - the platform actually used is still x64.
jirina
I will probably do that; it will take some time and effort, but it should resolve the problem.
Thank you for your help.
