29632 Discussions
Incorrect result with COUNT in initialization expression
Brian1
I found that Intel Fortran 15 gives incorrect results with the COUNT intrinsic in initialization expressions. Consider the following program:
program count_bug
  implicit none
  integer, parameter :: npts(2) = (/ 42, 1 /)
  integer, parameter :: ndims = count(npts .gt. 1)
  write (*,'(2(I0, 1X))') count(npts .gt. 1), ndims
end program
When compiled with ifort, the output is "1 -1".  The correct output is "1 1".
This result was obtained with Intel Fortran 15.0.1 20141022 on Mac OS X 10.10.1.
Right you are! Escalated as issue DPD200366183 - thanks for letting us know.
This was a rather interesting bug. Interesting in that it affected only rank-1 arrays - if you called COUNT with an array of two or more dimensions, I am told it worked correctly. I expect the fix to appear in Update 3.
