29594 Discussions
Incorrect variable value in debugger in OpenMP parallel region
jirina
I am debugging a code in an OpenMP parallel region, and I am experiencing a problem with an incorrect value of variable added to Watch. My (simplified) code is:
!$omp parallel if ( omp_body_forces ) num_threads ( threads ) default ( shared )
!$omp&  private ( k )
!$omp do schedule(auto)
    do k=k2,k1,-1
!$omp end do
!$omp end parallel
omp_body_forces is logical*1, value is .true., thread is integer*4, value is 1, k is integer*4, k1 and k2 ar local variables initialized outside the parallel region.
An incorrect value is shown for k added to Watch. If I comment out the parallelization, k in Watch has a correct value.
I can see k listed twice in Locals, once with an incorrect value, once with the expected value.
Is this an expected behavior of the debugger and Watch for variables inside an OpenMP parallel region, with number of threads set to 1?
