29400 Discussions
Index intrinsic function IVF return 0 for very big value
roy437
I have a program that turns a very large stl file (4.11GB) into a pts file "stl_to_pts.f90".  An example stl file:
solid ASCII STL file generated with VxScan by Creaform.
facet normal 0.284589 0.628278 -0.724069
outer loop
vertex -1166.990479 -277.309601 656.863098
vertex -1166.887573 -276.861084 657.292725
vertex -1166.407104 -277.144348 657.235779
endloop
endfacet
facet normal 0.287695 0.632549 -0.719106
outer loop
vertex -1166.523071 -276.255005 657.971680
endloop
endfacet
facet normal 0.408622 0.642011 -0.648730
outer loop
vertex -1166.527466 -276.258850 657.991821
vertex -1166.468018 -276.235260 658.052612
vertex -1166.257812 -276.307129 658.113892
endloop
endfacet
facet normal 0.082224 0.975477 0.204167
outer loop
endloop
endfacet
facet normal 0.466552 0.599195 -0.650611
outer loop
endloop
endfacet
facet normal 0.302361 0.775017 -0.554911
outer loop
vertex -1166.377808 -276.043121 658.370117
vertex -1166.155640 -276.129272 658.370850
endloop
endfacet
facet normal 0.409470 0.665844 -0.623687
outer loop
endloop
endfacet
facet normal 0.316780 0.659006 -0.682174
outer loop
vertex -1165.399780 -277.246002 657.605347
endloop
endfacet
endsolid
Source code:
    module read_fis
       character *260 fisi
       character(:), allocatable :: str
    end module read_fis
    subroutine read_file_to_string
    use ifport
    use read_fis
    implicit none
    integer *4 :: iunit, istat
    integer *8 :: file_size
    character(len=1) :: c
    open(newunit = iunit, file = fisi, status = 'OLD', &
            form = 'UNFORMATTED', access = 'STREAM', iostat = istat)
    if (istat==0) then
        inquire(file=fisi, size=file_size )
        if (file_size > 0) then
            allocate(character(len=file_size ) :: str)
            read(iunit, pos=1, iostat = istat) str
            if (istat==0) then
                !make sure it was all read by trying to read more:
                read(iunit, pos = file_size+1, iostat = istat) c
                if (.not. IS_IOSTAT_END(istat)) then
                    write(*,*) 'Error: file was not completely read: ', trim(fisi)
                end if
            else
                write(*,*) 'Error reading file: ', trim(fisi)
            end if
            close(iunit, iostat=istat)
        else
            write(*,*) 'Error getting file size: ',  trim(fisi)
        end if
    else
        write(*,*) 'Error opening file: ', trim(fisi)
    end if
    return
    end
!   Main program
    use read_fis
    implicit none
    character(:), allocatable :: a
    character *260 fise
    character  *10 ext
    character   *1 cr
    character   *2 crlf
    integer *8 i, j, m, i1, i2, k
    integer *4 np, kp
    cr = char(13)
    crlf = cr//char(10)
    call GETARG(1, fisi)
    call GETARG(2, fise)
    kp = index(fise, '.', back = .true.) + 1
    ext = fise(kp:)
    call read_file_to_string ! str = fisi
    m = len(str) ! /2
    allocate(character(len=m) :: a)  !   a = fise
    open(newunit = iunit, file = fise, status = 'NEW', &
    if(istat == 0) then
        continue
    else
        write(*,*) 'Error opening file: ', trim(fise)
        stop
    end if
    i = 1
    i1 = 1
    if(trim(ext) == 'pts' .or. trim(ext) == 'PTS') then
      np = 0
      do
         k = index(str(i:), 'vertex', kind = 8)
         if(k > 0) then
         	 np = np + 1
             i = i + k + int8(6)
             j = i + index(str(i:), cr, kind =  - int8(2)
             i2 = i1 + j - i + int8(4)
             a(i1:i2) = str(i:j)//' 9'//crlf
             i1 = i2 + int8(1)
         else
             write(99,'(i0,t11,i0)') k, i
             write(iunit, pos = 1, iostat = istat) a(:i2-2)
             exit
         end if
      end do
    else
      do
         k = index(str(i:), 'vertex')
         if(k > 0) then
             i = i + k + 6
             j = i + index(str(i:), cr)
             i2 = i1 + j - i
             a(i1:i2) = str(i:j)
             i1 = i2 + 1
         else
             exit
         end if
      end do
    end if
    deallocate(str)
    close(iunit)
    deallocate(a)
    stop
    end
I checked the "str" variable and it stores the entire stl file.
The program stops when k = 0 when it no longer finds the word "vertex". The last index found by the program is i = 121,513,698 although the last index in the stl file is 4,416,480,763. The question is: why does the index function return 0 after i = 121,513,698.
In "Project properties" it is set to "Default Integer kind": 8 (/ integer-size: 64), and in "Configuration Manager": x64, Release
I mention that I have:
I7-3770 processor, 16GB RAM, WINDOWS 10 Home / 64bit,
Intel Parallel Studio XE 2020 Update 4 Windows x64.
andrew_4619
I had a quick look at your program, and I didn't see the problem, it could be a compiler bug with >32bit character subscripts. If you think it is a bug make a minimal sample code that shows the problem that is easier all round.
There are some strange things in your code the text STL is a formatted file yet you open it as unformatted for example.
Functionally you could to what yo are doing in a much simpler way IMO. I made an ran a simple example below.
program txt_stl_2_pts
    implicit none(type, external)
    character(132) :: gin
    integer :: iun1, iun2, ip, istat
    character(*), parameter :: GA ='(A)'
    open( newunit = iun1, file ='winder_bed_type_LH.stl', status = 'old', iostat = istat)
    if( istat /= 0 ) goto 900
    open(  newunit = iun2, file ='output.txt', status = 'unknown', iostat = istat )
    do
        read( iun1, ga, iostat = istat ) gin
        ip = index(gin,'vertex')
        if ( ip > 0 )  write( iun2, ga) trim( gin(ip+6:) )
    enddo
    900 continue
    close (iun1, iostat = istat )
    close (iun2, iostat = istat )
end program txt_stl_2_pts
roy437
Please test : https://we.tl/t-PGVsUr5zzZ
Filesize = 4.11 GB
Tell me time to run. Time to run is big. Tell me performances of your computer and OS.
Thx, J. Roy
jimdempseyatthecove
FWIW line 87 looks invalid. This should have produced a compilation error.
Jim Dempsey
roy437
The correct line 87 is:    j = i + index(str(i:), cr, kind=8) - int8(2)
For test there is file : https://we.tl/t-PGVsUr5zzZ
J. Roy
JohnNichols
Valued Contributor III
What are the command line arguments?
JohnNichols
The first problem is you have a test file so large that even VEDIT cannot open it to look at it.   I have never seen a text file this large and I deal with huge FEM models.  I am not aware of a better editor than vedit for very large files.
The file is created as text numbers, often you run into a problem that the format statement that created the number is incorrect for the number, which happens a lot.   But I cannot read your file to look for errors in the text.
I suggest you write a simple program that reads and checks each line for correctness, this is a common thing for DXF files for industrial applications in some locations.
JohnNichols
! call GETARG(1, fisi)
    !call GETARG(2, fise)
    fisi = "Test.stl"
    fise = "Test.out"
    ext = fise(kp:)
    m = len(str) ! /2
    open(newunit = iunit, file = fise, status = 'UNKNOWN', &
Now I can run it in VS 2019 - see unknown, old means you have to delete the file to run it.
roy437
Ultraedit 64-bit read very large file.
JohnNichols
it is 99 per year, not going to spend the money.
 module read_fis
    character *260 fisi
    end module read_fis
    use ifport
    use read_fis
    implicit none
    integer *4 :: iunit, istat, ilog
    integer *8 :: file_size, I,k,m,n
    if (istat==0) then
        write(*,100)file_size
100     Format("File size is :: ",i10)
101     Format("File size is > :: ",i10," billion characters")
        ! write(*,100)file_size/1000
        !  write(*,100)file_size/1000000
        write(*,101)file_size/1000000000
            if (istat==0) then
                end if
            else
            end if
            k = 1
            open(newunit = ilog, file = "ab.log", status = 'unknown')
            do i = 1,200
                if(mod(1000,1) .eq. 0 ) then
                !close(ilog)
               ! open(newunit = ilog, file = "ab1.log", status = 'unknown')
                end if
                if(i .eq. 1) then
                m = k
                n = k + 56
                    write(ilog,1001)I,str(m:n)
                    m = n + 1
                    n = n + 46
                write(ilog,1002)I,str(m:n)
                m = m + 47
                n = m + 15
                write(ilog,1003)I,str(m:n)
                m = m + 16
                n = m + 49
                write(ilog,1004)I,str(m:n)
                m = m + 50
                n = m + 49
                write(ilog,1005)I,str(m:n)
                m = m + 50
                n = m + 49
                write(ilog,1006)I,str(m:n)
                m = m + 50
                n = m + 11
                write(ilog,1007)I,str(m:n)
                m = m + 12
                n = m + 11
                write(ilog,1008)I,str(m:n)
                m = m + 12
                n = m + 43
                else
                    m = n + 1
                    n = n + 46
                m = m + 16
                n = m + 49
                m = m + 50
                n = m + 49
                m = m + 50
                n = m + 49
                m = m + 50
                n = m + 11
                m = m + 12
                n = m + 11
                m = m + 12
                n = m + 43
                end if
1001            Format(I10,"  Line :: ", A57,\)
1002            Format(I10,"  Line :: ", A42)
1003            Format(I10,"  Line ::     ", A15,\)
1004            Format(I8,"  Line ::     ", A43)
1005            Format(I10,"  Line ::    ", A44)
1006            Format(I10,"  Line ::   ", A45)
1007            Format(I10,"  Line ::   ", (A),\)
1008            Format(I8,"  Line ::   ", (A)/)
            end do
        else
        end if
    else
    end if
    return
    end
    !   Main program
    use read_fis
    implicit none
    character *260 fise
    character  *10 ext
    character   *1 cr
    character   *2 crlf
    integer *4 np, kp
    cr = char(13)
    crlf = cr//char(10)
    fisi = "Test.stl"
    fise = "Test.out"
    ext = fise(kp:)
    m = len(str) ! /2
    if(istat == 0) then
        continue
    else
        stop
    end if
    i = 1
    i1 = 1
        np = 0
        do
            if(k > 0) then
                np = np + 1
                i = i + k + int8(6)
                ! j = i + index(str(i:), cr, kind =  - int8(2)
                i1 = i2 + int8(1)
            else
                exit
            end if
        end do
    else
        do
            if(k > 0) then
                i = i + k + 6
                i2 = i1 + j - i
                a(i1:i2) = str(i:j)
                i1 = i2 + 1
            else
                exit
            end if
        end do
    end if
    deallocate(str)
    close(iunit)
    deallocate(a)
    stop
    end
  I played with your code, str is very hard to take apart and even print.
Read one line at a time, find what you want and throw it away.  That you should be able to write in an hour.
roy437
Hooray,
I solved the problem, removed kind=8 and replaced index(str(i:) with index(str(i:i200) where i200=200. Execution time 11.70 sec. Thanks to everyone for the advice.
I7-3770, 16GB RAM, W10/64bit and ssd.
J. Roy
JohnNichols
11th Gen Intel(R) Core(TM) i7-11850H @ 2.50GHz 2.50 GHz
turn off the write to the file out and it runs in less than a second on 32 GB Win 11 and SAmsung SSD.
roy437
Wow, probably the best time, congratulations!
