29376 Discussions
Initialization of local variables in subroutines
Franco_B_
In Fortran 77 is it possible to globally ensure that the local variables in a subroutine are not preserved (which seems to be the default), i.e. without initializing all variables and arrays individually?
My problem is that calling a subroutine repeatedly results in different answers.
For example, if I send it an input value x, it returns the correct value y.
However, if I put it inside a loop and send it values x-1 and then x, it returns the correct output for x-1, but for x it now returns an incorrect value different to y.
mecej4
Local variables without the SAVE attribute are not saved unless the compiler option /Qsave is used. Under these circumstances, it is the programmer's responsibility to assign values to such variables before they are used. In terms of the standard, the value of an unsaved variable is "undefined" at subprogram entry, but there is no guarantee that its value will be different from the value that it had when the same subprogram was last exited.
I find your "without initializing .. individually" rather perplexing and contradictory. If you adopt a "don't ask, don't use" policy, it should not matter what the memory contains for a variable whose value, according to the Fortran standard, is "undefined".
mecej4
Arjen_Markus
As an addition to mecej4's explanation:
Some older compilers especially on Windows used to put local variables in static memory, so that they kept their value. That is not violating the standard, it merely means that if your code implicitly relies on local variables keeping their values (that is: no SAVE attribute) it just happens to work with such compilers - but not necessarily with others! Current compilers in my experience do not do this anymore.
