29359 Discussions
Install fortran compiler on ubuntu (x86-64)
hossein309
I try install fortran compiler on ubuntu 9.04 (x86-64) with use of this instruction
http://software.intel.com/en-us/articles/using-intel-compilers-for-linux-with-ubuntu.
following to instruction i install gcc, g++, libstdc++5, and also install ia32-libs, lib32stdc++6, libc6-dev-i386, gcc-multilib, g++-multilib and i copy libstdc++.so.5 to /usr/lib but during installation installation script reguest this libraries:
libstdc++
libstdc++5
glibc
libgcc
How i can resolve this problem ?
TimP
Quoting - hossein309
libstdc++
libstdc++5
glibc
libgcc
If you wish to install both the ia32 and the intel64, you must have both the 32- and 64-bit g++ development installations active. For intel64 alone, you would require the full g++ development installation only for 64-bit, which presumably you have already installed. I'm guessing you tried to install the ia32 ifort without full 32-bit g++.
hossein309
Quoting - tim18
I only want 64 bit compiler on a 64 bit linux. I already installed ifort ia32 on a 32 bit linux.
