Installation stops
Rosman__Paulo
In trying to install parallel_studio_xe_2020_cluster_edition_setup.exe, after extracting all the files, the process stops and I get the following message in the end of the log file, right after the line ....\parallel_studio_xe_2020_cluster_edition_setup\install.exe was launched
27.04.2020 16:16:10 : 16136 :   Child window was NOT found
27.04.2020 16:16:11 : 16136 :   The following child window found: Intel(R) Parallel Studio XE 2020 for Windows*
27.04.2020 16:16:11 : 16136 :   Child window was found
27.04.2020 16:16:11 : 16136 :   Waiting end of child process...
27.04.2020 16:16:46 : 16136 :   Return Code of child process: -1073741819
27.04.2020 16:16:46 : 16136 :   Setup.exe was launched
27.04.2020 16:16:46 : 16136 :   Finish
27.04.2020 16:16:46 : 16136 : WARNING : Return Code is overwrited by Setup.exe return code. [ret code] = 1000 + [setup.exe ret code]
27.04.2020 16:16:46 : 16136 :   Return Code: -1073740819
Any hint?
I thank you in advance,
Paulo Rosman
