Installation to Linux VM
Huang__Liying
We have the project working in Window with Intel Fortran Compiler for years and like to see if
we can compile the project in Linux VM before we buy the Linux license, I tried the trial version
and when I install, I got this error:
Missing critical prerequisite
-- Xorg X11 libXss runtime library is not found. 'Graphical user interface'
component of VTune Amplifier cannot be installed.
Wonder if I could install the Fortran Compiler without the graphical user interface? Thanks!
Liying
Juergen_R_R
Valued Contributor II
You downloaded the complete package including the VTune profiling tools. I think when you just download the Parallel Studio component and not the full package then you don't need X11 and graphics support.
Huang__Liying
I have tried the customized package, as my VM is Intel 64, I choose
Select the target architecture(s) where the applications you develop will run.
   1. [ ]    IA-32
   2.     Intel(R) 64
and I have choose:
  1. Accept and continue [ default ]
   2. [None] Intel Trace Analyzer and Collector 2019 Update 3
   3. [None] Intel Cluster Checker 2019 Update 2
   4. [None] Intel VTune Amplifier 2019 Update 3
   5. [None] Intel Inspector 2019 Update 3
   6. [None] Intel Advisor 2019 Update 3
   7. [All] Intel C++ Compiler 19.0 Update 3
   8. [All] Intel Fortran Compiler 19.0 Update 3
   9. [All] Intel Math Kernel Library 2019 Update 3 for C/C++
   10.[All] Intel Math Kernel Library 2019 Update 3 for Fortran
   11.[All] Intel Integrated Performance Primitives 2019 Update 3
   12.[All] Intel Threading Building Blocks 2019 Update 4
   13.[None] Intel Data Analytics Acceleration Library 2019 Update 3
   14.[None] Intel MPI Library 2019 Update 3
   15.[None] GNU* GDB 8.0
   16.[None] Intel(R) Distribution for Python*
but after I accept configuration and begin install, I got:
Missing optional prerequisites
-- missing system commands
-- 32-bit libraries not found
Please advice what I need to do to get this resolved? Thanks!
Liying
Steve_Lionel
First, I'll comment that you don't need Threading Building Blocks nor Integrated Performance Primitives as those are for C/C++ only.
You need the 32-bit gcc libraries: Development for a 32-bit on a 64-bit host may require optional library components (ia32-libs, lib32gcc1, lib32stdc++6, libc6-dev-i386, gcc-multilib, g++-multilib) to be installed from your Linux distribution.
Also:
Linux Developer tools component installed, including gcc, g++ and related tools. (this is the list of component versions tested by Intel; other versions may or may not work and are not recommended - please refer to Technical Support if you have questions
gcc 4.4 to gcc 7
binutils 2.20 to binutils 2.29
Library libunwind.so is required in order to use the -traceback option.  Some Linux distributions may require that it be obtained and installed separately.
Huang__Liying
I checked, both gcc and binutils are already installed when installed devtool,
Package binutils-2.27-34.base.el7.x86_64 already installed and latest version
gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/libexec/gcc/x86_64-redhat-linux/4.8.5/lto-wrapper
Target: x86_64-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man --infodir=/usr/share/info --with-bugurl=http://bugzilla.redhat.com/bugzilla --enable-bootstrap --enable-shared --enable-threads=posix --enable-checking=release --with-system-zlib --enable-__cxa_atexit --disable-libunwind-exceptions --enable-gnu-unique-object --enable-linker-build-id --with-linker-hash-style=gnu --enable-languages=c,c++,objc,obj-c++,java,fortran,ada,go,lto --enable-plugin --enable-initfini-array --disable-libgcj --with-isl=/builddir/build/BUILD/gcc-4.8.5-20150702/obj-x86_64-redhat-linux/isl-install --with-cloog=/builddir/build/BUILD/gcc-4.8.5-20150702/obj-x86_64-redhat-linux/cloog-install --enable-gnu-indirect-function --with-tune=generic --with-arch_32=x86-64 --build=x86_64-redhat-linux
Thread model: posix
gcc version 4.8.5 20150623 (Red Hat 4.8.5-36) (GCC)
I don't use -traceback option, so Library libunwind.so is not necessary...
Any other suggestions?
Steve_Lionel
Try customizing the compiler component to install only the x64 part. It is trying to install the 32-bit compiler as well.
Huang__Liying
I did unselect IA-32, but it still tries to install 32-bit compiler, there is nowhere else than below
that I can unselect IA-32.
   1. [ ]    IA-32
   2.     Intel(R) 64
Huang__Liying
Strange, I go ahead ignoring the missing component and it seems to be installed successfully.
Thanks!
Liying
Huang__Liying
Hi Steve,
I  need to link Fortran code with c code, I have compiled and linked everything, but I got error when I execute it,
the error message is: undefined symbol: __svml_log2, I google and found out there was an old inquiry that
you replied to include libsvml.a, I wonder if it is due to some components that I didn't install, so the library is
missing? I only installed Fortran related component, but gcc is installed when I installed development tookl.
Thanks!
Liying
Steve_Lionel
libsvml.a is part of Intel Fortran and C++. If you use ifort to link, which is usually recommended, this should get referenced automatically.  Otherwise you will need to name it on the command used to link.
Huang__Liying
Hi Steve,
My project requires to use gcc to link, wonder if you can offer some advice how to name it on the command?TThanks!
Liying
Steve_Lionel
Like any other library, -lsvml . The path to libraries should already be established once you "source" the ifortvars.sh (or .csh) script.
You can use ifort to link even with gcc objects. It ends up calling ld anyway.
Huang__Liying
Hi Steve,
I have got over that issue, now error message is:
ERROR: /home/lxh37/Desktop/proc_lca/lca: undefined symbol: __kmpc_ok_to_fork
I searched and it seems that I need to use -lpthread and libiomp5 library? I did both,
but couldn't get rid of the error, any other advice? Thanks!
Liying
Huang__Liying
I figured it out, I also need to add -liomp5 option...
Huang__Liying
Now I have message
undefined symbol: for_f90_index
search around, don't know which library I should include for this one....
Liying
Steve_Lionel
Probably -lifcore
si_lakhal__bahia
Hi
I downloaded parallel studio_xe_2019 cluster edition; initial release then the update 3. I need fortran compiler to use planck likelihood plc-2.1_py3 I sourced the tool by  putting in my .bashrc source psxevars.sh intel64 as indicated in the installation instruction of the product. the which ifort command gives the answer /opt/intel/compilers_and_libraries_2019.3.199/linux/bin/intel64/ifort.
But when i configure plc-2.1_py3 I got the message ifort not found. Could someone help me find the issue?
With my best regards
