- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
I installed the Intel Fortran Compiler on my Debian 32 bits.
The installation went well until the point where I need to:
source install-dir.bin/ifortvars.csh (and.sh) ia32
where this error appears:
LANGUAGE_TERRITORY: Undefined variable
and I'm not able to use the ifort
any clues ??
best regards,
- Marcas:
- Intel® Fortran Compiler
Link copiado
6 Respostas
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
what shell are you using?
echo $0
will tell you this information. Also, is this a US English language system or have you set a different locale ( env vars LANG, LC_ALL, etc.)
ron
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
I use a tcsh shell.
My debian was originally a german version but I change the local settings to english, with the help of dpkg trvonfigure locales.
Is that the problem ?
thanks
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
it probably is the language/locale.
tcsh should be ok with
source /opt/intel/bin/compilervars.csh ia32
However, we do not test against tcsh so it is possible there is something incompatible.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
You are not testing this? Well, it also shows up with RHEL6.
Are you serious? _I_ choose between bash and tcsh (at the very least), not you.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Bob- Did you ever find a solution for this? I am having the same problem with RHEL 6.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Bob H. wrote:
Are you serious? _I_ choose between bash and tcsh (at the very least), not you.Certainly, we can all use our favorite shell for routine work. However, I don't see it as a hardship if a vendor stipulates using a different shell just for a one-time installation. Is it not better for the vendor to do thorough testing on the system default shell rather than test (less thoroughly, perhaps) on a number of different shell and Linux distro combinations? In Windows, we rarely get to stipulate which installer package is used, so why is this a major issue in Linux?
Responder
Opções do tópico
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
