Context:
Vista Ultimate x64
Intel Fortran 10.1.019, 10.1.021, 10.1.024
Problem:
I have been installing updates on top of previous installations. With the installation of a third update (v10.1.024), VS2008 reverted to using the oldest version I had installed (v10.1.019).
I could not find any option in VS2008 to select the compiler version. The menu optionTools > Options > Intel Fortran > Compilersmentioned in the documentation (...v10.1.024w_fc_p_10.1.024_INSTALL.htm) does not exist in VS2008.
The apparent fix was touninstall the oldest version. After doing that, VS2008 automatically started using the latest compiler version.
Questions:
Should I have the menu item mentioned above in my VS2008 environment?
I initially installed the compiler before integration with VS2008 was available, so I installed the VS2005 version that came with the compiler. Can I safely remove that now? Worried that uninstalling it will remove the compiler integration from VS2008 too.
What is the best practice for installing compiler updates? It appears that one should uninstall all but one version prior to installing an update.
I went ahead and uninstalled VS2005 Premier Partner. I removed the following components:
Microsoft Visual Studio 2005 Premier Partner Edition
Microsoft Visual C++ 2005 Redistributable
Microsoft Document Explorer 2005
Was not sure about these, so I left them:
Visual Studio .NET Prerequisites - English
Visual Studio 2005 Tools for Office Second Edition Runtime
It did not break VS2008 compiler integration.
In VS2008 RTM, Tools->Optionsat the lower leftunder the ListBox.
