29656 Discussions
Installing Visual Fortran Compiler Professional Edition (Version: 11.1 Build: Update 7 Eng)
Johannes_S_2
Hi *,
during Installing Visual Fortran Compiler Professional Edition incl. Microsoft Visual Studio 2008 Shell and Libraries (by just executing Setup.exe) I received the following Pop-Up:
"Error while installing package
C:\\TEMP\\Intel\\Download\\fw_cprof_p_11.1.067\\installs\\1033\\w_cprof_ide_ia32_emhe_p_11.1.067/w_cprof_ide_ia32_emhe_p_11.1.067.msi"
Do I have to install something before executing Setup.exe? All hints are welcomed.
Cheers,
Thomas
mecej4
One cause of such problems can be inadequate free space in the %TEMP% and/or %TMP% directories to extract the distribution files during the course of the installation.
Johannes_S_2
That is not the case. There is only partition and there are still 100GB of free disk space. In the log-files which I received after the installation has failed I found the following error messages:
26089:Property(S): ErrorDialog = SetupError
26890:Internal call: error code: 259 (There are no more files available
87231:Property(S): ErrorDialog = SetupError
89391:MSI (s) (7C:80) [15:54:20:947]: Note: 1: 2228 2: 3: ServiceInstall 4: SELECT `Name`,`DisplayName`,`ServiceType`,`StartType`,`ErrorControl`,`LoadOrderGroup`,`Dependencies`,`StartName`,`Password`,`ComponentId`,`Directory_`,`FileName`,`Arguments` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
89937:@echo ERROR: Unknown switch '%1'
89942:@echo ERROR: Unknown switch '%2'
90107:@echo ERROR: Unknown switch '%1'
90112:@echo ERROR: Unknown switch '%2'
90654:Property(S): ErrorDialog = SetupError
91516:MSI (s) (7C:58) [15:55:07:994]: Internal MSI error. Installer terminated prematurely.
Any ideas?
Thomas
rase
