Installing failed!
Magne_R_
Hi Steve!
I tried install both a CVF 6.5 and 6.6 version we have, but neither of them would install. The main setup.exe reported that the exe file was valid, but for a machine type other than the current one. When i tried the setup.exe in the x86 directory I got up the first picture. But, when I press the Install button the program seems to terminate. How do we progress? Any ideas?
Thanks in advance!
Magne
Les_Neilson
Valued Contributor II
What hardware and Operating System are you trying to install on ?
Les
Magne_R_
I've got a Dell Precision 670 with Windows XP x64withdual intel Xeon processors.
Magne
Well, maybe it just doesn't work then. Ordinarily your symptom would make me suggest that you're installing the Alpha version, but 6.6 didn't have that.
Time to switch to Intel Visual Fortran? Then you can get a compiler that knows how to generate 64-bit code.
