Installing the IDE Problem
knebel
Hello
I am trying to install a Trial version of IVF 9.1
I have also installed VS.2005 and FTN95.
And some time ago IVF 8.1
When trying to install the IDE I get the following message :
You have a prevously integrated Compiler with Visual
Studio, quit this install and uninstall the previous
version prior to installing this one.
What previous version is meant here ?
I have deinstalled IVF 8 but I still get this message.
What can I do ?
regards
Klaus
It means a previous version of the Visual Studio integration for Intel Fortran. Do you see an entry for that in Add or Remove Programs? I have seen some cases where it looks as if the previous integration was installed but some registry entries remained. If the uninstall does not work (or there's nothing to uninstall), please open an issue with Intel Premier Support to get assistance.
knebel
Thanks for the fast answer.
That is the problem, that there is 'nothing' to uninstall.
How can I contact the Premier Support ?
See here.
