29334 Discussions
Insufficient memory to allocate Fortran RTL message buffer, message #174 = hex 000000ae.
brickflying
I met this error when run a procedure
What kind of error in code will cause?
Martyn_C_Intel
In case it's helpful, here is an example in another post:
http://software.intel.com/en-us/forums/showthread.php?t=59041
I suggest you turn on more diagnostics, such as -gen-interfaces -warn interfaces and-check
Also, if you call any RTL functions, be sure to USE IFLPORT so that you get the benefit of interface checking at compile time.
