29487 Discussions
Integration problem of oneAPI 2024 with Visual Studio 2019 on Windows 10
qiuck16
I installed oneAPI 2024 successfully but when I created a Fortran project, the error appear, as follows:
Tool path doesn't exist or nor set "\bin32". Make sure install directory environment variable is defined.
Try to re-install the product to fix t
Labels (2)
Ron_Green
In the Project Configuration, set the build to x64.  Does that work?  Which compiler are you using, ifx or ifort?
qiuck16
The build platform is x64 by default, and the default compiler is ifx.
Devorah_H_Intel
What is the version of VS 2019? Please provide the info from Help>About Microsoft VS.
See validated VS 2019 versions
Are you able to create a new Fortran project?
qiuck16
It is Visual Studio Community 2019 version 16.11.32. I can create and build a Fortran project and then run the program.
JohnNichols
Honored Contributor I
That program is so old you, you need to update to a modern VS try 2022 or the preview.  You are wasting time on old stuff.
VS has moved on and so has Intel.
Ron_Green
So if I understand, you have an existing Fortran Solution or Project.  After you upgraded to Intel Fortran 2024 it won't build.  But if you create a new project you can compile and run.
So the old project file must have some 32bit dependency or other.
You have 2 choices - if the number of files is small-ish, I would create a new Solution/Project and include all the sources.  Start with a clean project file using ifx.
or
use this guide in the Developer Guide  to set the default compiler to ifort and you should be able to build.
