29653 Discussions
Integration with Visual Studio (again...)
Massimo
Greetings,
I've got a new PC with Windows 10. The IT staff has installed Intel Fortran Compiler 16.0 before I could get my hands on, so that Visual Studio (Community 2015) was installed later and the compiler is not integrated. I have tried following the instructions at http://software.intel.com/en-us/node/159008?wapkw=fortran
cd %VS140COMNTOOLS%
cd ..\..\Intel Fortran\VFPackages
integrate.bat "%VS140COMNTOOLS%" /u
but I get immediately an error message saying "The system cannot find the path specified". Any idea of how I can get the compiler integrated in VS? Below are detailed information about my VS installation.
Thanks in advance.
Microsoft Visual Studio Community 2015
Version 14.0.23107.0 D14REL
Microsoft .NET Framework
Version 4.6.00079
Installed Version: Community
Visual Basic 2015   00322-20000-00000-AA924
Microsoft Visual Basic 2015
Visual C# 2015   00322-20000-00000-AA924
Microsoft Visual C# 2015
Visual C++ 2015   00322-20000-00000-AA924
Microsoft Visual C++ 2015
Visual F# 2015 RC   00322-20000-00000-AA924
Microsoft Visual F# 2015 RC
Application Insights Tools for Visual Studio Package   1.0
ASP.NET and Web Tools   14.0.20626.0
ASP.NET Web Frameworks and Tools 2013   5.2.30624.0
For additional information, visit http://www.asp.net/
Common Azure Tools   1.5
Provides common services for use by Azure Mobile Services and Microsoft Azure Tools.
GenerateUnitTest   1.0
Generates unit test code for methods in classes under test.
Microsoft Azure Mobile Services Tools   1.4
NuGet Package Manager   3.0.0
NuGet Package Manager in Visual Studio. For more information about NuGet, visit http://docs.nuget.org/.
PreEmptive Analytics Visualizer   1.2
Microsoft Visual Studio extension to visualize aggregated summaries from the PreEmptive Analytics product.
Python Tools for Visual Studio   2.2.30718.00
Python Tools for Visual Studio provides IntelliSense, projects, templates, Interactive windows, and other support for Python developers.
Python Tools for Visual Studio - Django Integration   2.2.30718.00
Provides templates and integration for the Django web framework.
Python Tools for Visual Studio - Profiling Support   2.2.30718.00
Profiling support for Python projects.
SQL Server Data Tools   14.0.50616.0
Microsoft SQL Server Data Tools
Kevin_D_Intel
I expect the error relates to a missing "..\..\Intel Fortran\VFPackages” folder.  I believe that may be missing in your case due to the installation order. Since VS2015 did not exists when the Intel 16.0 compiler was installed that means %VS140COMNTOOLS% would not have been set; thus, the Intel installer would have no reason to create the Intel Fortran\VFPackages folder under the VS2015 path found in that environment variable.
I believe Steve’s the troubleshooting guide is used in situations where the prescribed installation order is followed (i.e. VS first and Intel compiler second) and thus the VFPackages folder would exist.
Unfortunately, in your case, I have to recommend you uninstall the Intel Parallel Studio XE 2016 product and reinstall it; making certain during the installation to select the integration with VS2015. That seems necessary because the Uninstall/Change option will not offer enabling VS2015 integration for an existing IPSXE 2016 installation where VS2015 was installed after IPSXE 2016. I have that very scenario on my system now and the option to integrate with VS2015 is greyed out. I will have to follow-up with our installation team about why this is. (My hunch is it relates to not keeping around the intermediate installation files when the package is first expanded.)
Sorry for the added steps/headache.
TimP
There is a choice during ifort installation whether to remove the expanded files in the Download folder.  If they are still there, the setup.exe in that folder may be used to remove and re-install.  Otherwise, if the full offline download package is available, remove and re-install still doesn't take more than a few minutes.
Massimo
Indeed, uninstalling and reinstalling was the right path, and quick enough indeed. Thanks for your suggestions.
Kevin_D_Intel
Glad to hear that. Thank you.
