Intel 9.1 (039) Compiler Hangs
jcjodoin
All,
What in general causes the ifort compiler to hang?
I have a 2983 line fortran file with a large number of locals, and some character variable types (and functions).
I've been told by others that this combination is something that the compiler regularly barfs on.
I am a bit concerned since this code (f90 code translated from f77 code) compiled fine in the f77 Unix environment
it came from.
Any suggestions? Debugging I can do on the ifort itself to see where its getting stuck?
For grins, I let it run overnight last night on the 1 file that it hiccups on. It ran at 50% CPU all night long (12 hours).
I'd post code snippets -- but due to Intellectual Property considerations-- I can't.
Thanks much,
jeffrey
By hang you mean goes into a CPU-bound loop? A compiler bug can cause this, or in some cases, an optimization algorithm that just takes too long for a certain program. 9.1 is quite old at present - please try this with 11.1.
jcjodoin
Looks like a processing infinite loop error.
I updated to the new compiler ... 11.1 ... and it still bombs.
Is there a way I can debug ifort.exe to figure out where it is getting stuck?
jeffrey
No. You can use Intel Premier Support to report the problem and provide a test case in a secure manner.
