29657 Discussions
Intel Code Coverage Tool for Fortran
slialgor
Supposedly,
I have 10 exe files and all of them are from Intel Fortran Compiler with the right compiler options.
These exe files have their own testing models, and cannot be mixed.
I run 100 testing models with these 10 exe files, such as 10 models for each exe.
Then I have 100 *.dyn files.
Can I merge these 100 dyn files into one dpi file, since dyn files could be for different exe files?
If YES,
After merging these 100 dyn files into one dpi file, I want to generate the html reports for these 10 exe file separately.
Is this doable? Or I must have 10 dpi files?
thanks a lot.
You will need 10 dpi files, one for each exe.
