29618 Discussions
Intel Debugger Java Error on RHEL 6.5
chauvjo
I am running Red Hat Enterprise Linux 6.5 and am seeing the following java SIGABRT error when running Intel Debugger for applications running on Intel 64 Version 13.0 (2013 SP1 Update 4). The command that generated the error is also shown:
Process: /usr/lib/jvm/java-1.7.0-openjdk-1.7.0.65.x86_64/jre/bin/java was killed by signal 6 (SIGABRT)
cmdline:  java -jar /opt/intel/composer_xe_2013_sp1.4.211/debugger/gui/intel64/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar -showsplash -gui -native -tty /dev/tty
