29383 Discussions
Intel Fortran Compiler for Mac OS 10.5 Tiger?
thomaspatko
I have some programs that need to be compiled from source using a good Fortran compiler for Mac OS (computational chemistry programs specifically) and I understand that Intel is currently the best option available.
Has anyone tested the current version of the Intel Fotran compiler 10 for Mac OS on a beta (developer) release of Tiger with the new version of XCode?
I do not want to purchase the current student version (as it does not come with updates per my understanding) unless it will work on Tiger as I plan to upgrade shortly.
Any thoughts would be appreciated.
--Thomas
The Intel Premier Support site works for me at the moment.
I'd suggest getting the current compiler version as the one you have has had issues on Leopard.
alain_hebert
I found the problem and my code is working fine now. Here is the problem: I first install Build 20080312 from the DVD Intel sent me. Doing "ifort -V" returned "Intel Fortran Compiler for applications running on Intel I32". Next, I reinstalled the SAME build from the Intel Website. Now, "ifort -V" is returning "Intel Fortran Compiler for applications running on Intel 64" and everything is working! Note that I am always using the "-m32" switch in my configuration scripts. There is something I miss in the installation process.
TimP
Intel compilers don't observe the -m32 switch, which selects gnu 32-bit compilation and linking. Intel 32- or 64-bit compilers are installed in separate directories, selected by setting environment variables, as by the corresponding ifortvars and iccvars scripts. gcc -m32 will work in mixed builds only with the ifort 32-bit.
