29649 Discussions
Intel Fortran Compilers on Linux - Red Hat Enterprise
mmancini
Greetings. I'm having trouble accessing the Intel Fortran Compiler that I just installed on a machine running Linux Red Hat Enterprise. I installed the packages according to the INSTALL.txt, and then ran /opt/intel/fc/9.0/bin/ifortvars.sh to set the enviroment variables. When I log on as a standard user, it says it doesn't see the command I am using to run the compiler.
I used a Serial number when activating the installation, and I'm not sure if I need to download any FlemLM license manager or whatnot.
Any help is appreciated.
TimP
If the ifortvars script works, you should see the compiler /bin directory in the PATH environment variable, and the /lib/directory in LD_IBRARY_PATH. That should be sufficient for the ifort command to be recognized. If the installation completed normally, the license should have been copied to a place where the compiler looks for it. License problems would not prevent the ifort command from being found, they would generate an explicit error message. You would need flexlm only for a floating license.
mmancini
Okay, I checked the env and for the PATH I get this:
PATH=/opt/intel/fc/9.0/bin:/usr/pgi/linux86/5.2/bin:/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/X11R6/bin:/root/bin
And for the Library I get this:
LD_LIBRARY_PATH=/opt/intel/fc/9.0/lib
My questions is following:
I used to have PGI Group Compilers installed and I'm not sure if I need to remove that from the PATH or not (as you can see it's listed in the PATH above, also). I have this question, because when I run the command "ifort" as root, it says it needs me to specify files (which means it knows the command, but the command is incomplete). However, when I run the command as a common user without root access, it says command not found. I also ran /opt/intel/fc/9.0/bin/ifortvars.sh as that specific user, but to no avail.
Thanks for all the help!
Did you use the "source" command as specified in the documentation?
