29488 Discussions
Intel Fortran Composer & Eclipse/Photran & Ubuntu 10.10 64 bits
Peter_Down
Hallo, I try compiler my fortran program on photran, on a 64 OS. I receive a messege about "Launsch failed. Not found binaries" but I made a makefile properly. I dont know any solution?? Can you help me!
Thanks!
TimP
You would still require a step to set the PATH and LD_LIBRARY_PATH for ifort, same as is done by sourceing the ifortvars script, in case that's your problem.
