29648 Discussions
Intel Fortran Debugger problem: unable to start debugging
mdi7
I am trying to debug a simple Fortran code using intel fortran 9.1 and visual studio.net 2003.
When I start to use the debugger, the following error message appears:
unable to start program:'c:..program.exe ' (where program is the name of my executable)
the server threw an exception.
I am using an windows xp pro dual core machine in a network.
As an issue to solve the problem, I tried to login into my computer as an administrator with all the rights, but I get the same error message.
Has this problem been submitted before
Regards.
What are the versions of the files by the given names in the PackagesDebugger folder?
Giel_H_
For CppEE.dll version 7...
For NatDbgEE.dll version 11..
The rest is obvious.
That's correct, then. If you're still having problems, I suggest:
1) Uninstall Intel Fortran
2) Do a "Repair" on Visual Studio 2003
3) Reinstall Intel Fortran
Giel_H_
Steve,
I tried your suggestion and it didn't work.
Should I escalate the problem as an issue to quad or do you have yet another suggestion?
I used a system restore to go back to version 11.0.066 and this version is OK.
In order to complete post #16:
If I start the program without using the debugger the error messages are:
1. unable to start debugging
2. unable to start program: 'Debugprogram.exe'
(where program is the name of my executable and where I used a Debug configuration).
3. The system cannot find the file specified.
If I start the program (with the debugger), the messages are:
2. The debugger is not properly installed.
3. Run setup to install or repair the debugger.
Install or repair the debugger doesn't solve the problem.
Finally, when doing a repair or modify action the screensof version 11.1.048 update 2 are confusing about whether the Intel Parallel Debugger is included or not in this version:
During the custom installation I cannot add this debugger (it is permanently deselected with a red cross).
During a repair or modifya screen appears stating that this versioncontains theIntel Parallel Debugger.
Kind regards,
Giel Habets
At this point, I do suggest you file a report with Intel Premier Support.
Giel_H_
Intel Premier Support has sent me a small Console6 "Hello World" Fortran Solution Example; that solution could be started without generating the above-mentioned error messages.
I discovered that the configuration propertiessettings had different entry values at Configuration properties - Debugging - Action - Command.
The Command entry should contain the (target) path to the executable;I inherited the following:
$(OutDir)program.exe
(where program is the name of the project).
The Console6 example solution contains in the Command entry:
$(TargetPath)
Changing the Command entry to $(TargetPath) solves the issue.
As a result, $(TargetPath) should be used for compiler version 11.1.048 and higher.
Kind regards,
Giel
This is not compiler-specific. Perhaps your project had been set so that the linker output was not named "program.exe" (or whatever you had there, or it was not placed in the output directory. $(TargetPath) is typically the default.
I'm glad to hear that you got the problem resolved.
Giel_H_
I can imagine that the integration of the Fortran compiler with Visual Studio has changedfor version 11.1.048 and higher.
Giel
I'm not aware of any changes in the integration.
