I use Intel compiler fortran with VS for 15 years now .
But I have difficulties to use the the debugger with IFX version.
I understand i have to install Intel® Fortran Expression Evaluator (FEE) extension manually
Can you explain the procedure to install it? Thank you.
From Visual Studio select the "Extensions" menu, then "Manage Extensions" => type "intel fortran expression evaluator" to search for the extension and install it.
There is an interesting discussion here about the FEE:
Thank you, it is done.
Nethertheless, I have still troubles for the allocated tables .
In the specification of the intel Fortran Expression it is written:
"The Intel® Fortran Expression Evaluator allows developers to:
- Evaluate Fortran expressions during debugging. (ok for me)
- Check the values of variables or compute custom expressions on-the-fly. (ok for me, it must be in UPPER CASE , ok)
- Support array slicing, derived types, and some Fortran intrinsic functions (e.g. ALLOCATED, ASSOCIATED, LOC) ." (not ok for me).
Maybe i have forgotten something or there is a restriction , or i need probably to install something else?
A simple example below: impossible to read the value Tab_XY
It works for me even in lower case (although tab_xy is displayed in upper case in the Watch window).
I'm using Visual Studio Community 2022 version 17.14.20 and ifx 2025.3.0
