Hi
We have installed the Intel oneAPI Base and HPC tool Kit. We are facing below issues.
Please help us.
Below is the screenshot for your reference.
You're not using Intel Fortran in that compile - it looks to me like gfortran. You're also using nonstandard syntax which Intel Fortran accepts (I format without width, extraneous parentheses on a WRITE) but gfortran does not.
Hi
I checked and while compiling the model, I am getting following error in Easy 5 model. Please support.
Such questions and requests should be posted in a forum that is related to the software in question: Easy5 . As Steve Lionel said, the issues and questions have nothing to do with the Intel OneAPI Fortran compiler. Ifort compiles the following code without complaints, despite the extra parentheses:
program easy
character(20) para_desc(100)
real para_val(100)
write(1,101)((trim(para_desc(i))), para_val(i))
101 format(A,',',G)
end
More to the point - you are NOT using Intel Fortran here, but rather some other, non-Intel compiler. It's not appropriate to ask for help with this here.
