29653 Discussions
Intel Fortran compiler linux cannot open a.out file
lihapulla
Dear friends,
I am a newbie and trying to get the Intel Fortran compiler 10.1.012 running on my Linux machine (Ubuntu 7.04). I tried making a simple program from a book. The program is called ch0701 and saved it as ch0701.f90 in a folder called fortran_tests.
The compiler lives in /home/gaw/fortran_compiler. Then I ran the compiler from the terminal /home/gaw/fortran_compiler/bin by typing ./ifort /home/gaw/fortran_tests/ch0701.f90 (my user directory is gaw). My machine thinks for a moment and then replies "ld: cannot open output file a.out : Permission denied".
Can anyone help me with this? Thanks in advance.
Gijs
TimP
It's entirely normal to install the compiler in a directory where you don't have write permission. Why not start out by doing things the normal way; install the compiler in default directories, source the ifortvars script to set up the compiler paths, and try your compilation in a directory owned by you, under your home directory? When you don't specify where a.out is to be created, the compiler will attempt to put it in the current directory.
lihapulla
Hahahaha, thank you for your sarcastic comment, I had a good laugh (at myself). It turned out I pressed a 1 for root install instead of a 3 for user account install during the installation and everything got installed in the root, where my user account doesn't have all permissions. Thanks for the wake up, I hope my next IQ test goes more fluently! :D
