Intel Fortran compiler
Sherif_Yehia
Dear sir
Good day
I downloaded  and setup intel fortran compiler
1- l_BaseKit_p_2022.2.0.262_offline.sh
2-l_HPCKit_p_2022.2.0.191_offline(1).sh
 I set them up  and  when I run    mpiifort --showme    I get the error in number 4
1-[sherifyehia@192 bin]$ which mpirun
/usr/local/bin/mpirun
2- [sherifyehia@192 bin]$ which mpif90
/usr/local/bin/mpif90
3-[sherifyehia@192 bin]$ which mpiifort
/opt/intel/oneapi/mpi/2021.6.0/bin/mpiifort
4- [sherifyehia@192 bin]$ mpiifort --showme
ifort: command line warning #10006: ignoring unknown option '-fshowme'
ld: /opt/intel/oneapi/compiler/2022.1.0/linux/bin/intel64/../../bin/intel64/../../lib/icx-lto.so: error loading plugin: libimf.so: cannot open shared object file: No such file or directory
  Can you please help me to figure out  my mistakes
Thanks for your time and effort.
PS my Operating system Red Hat Enterprise Linux 8.6
[sherifyehia@192 opt]$ find /opt/ -name "libimf.so"
/opt/intel/oneapi/compiler/2022.1.0/linux/compiler/lib/ia32_lin/libimf.so
/opt/intel/oneapi/compiler/2022.1.0/linux/compiler/lib/intel64_lin/libimf.so
/opt/intel/oneapi/itac/2021.6.0/bin/rtlib/libimf.so
/opt/intel/oneapi/clck/2021.6.0/lib_common/intel64/libimf.so
Sherif_Yehia
Hi
  was that answer
Please help
JohnNichols
Honored Contributor I
1. I provided the link to the documentation.
2. The documentation is always a good place to start.
3.  showme is not listed as one of the command flags for your program, to find that I ran the following commands as shown on the figure.
4. There are lots of manuals at  https://www.mpi-forum.org/docs/
5. You may get a better answer here, but based on the time that has passed you are asking a question no one can answer,  I certainly cannot answer it.
6. The hard part of programming is the reading to learn new stuff.   I am sorry but it appears that you will have read the basic manuals and get the correct commands.
7. Or as  I used to tell my grad students, find another grad student who has done it.
JohnNichols
run the most basic command without any parameters and let us see what you get,  we may be able to nut it out.
Sherif_Yehia
Thank you for your effort and time
Ron_Green
another thought: do you use bash, and did you 'source /opt/intel/oneapi/setvars.sh' ?
the .so it's looking for is in the ICX compiler - the C++ compiler in oneapi.  Not sure why it's looking for that .so, it should not need it.  Are you using -pgo  or -ipo or -fast compiler options?
Barbara_P_Intel
Intel's implementation of MPI is based on mpich. That --showme option is documented for OpenMPI, not for mpich.
It looks like -show is the equivalent for Intel's MPI and mpich.
