Intel Fortran compiler
ksasidhar
I am using intel fortran 10.0.023 for my simulations. I am trying to carry out specific computation which works on few computers and does not work on others. The statement is as follows.
DO i=1,3
IF (position(i) == TWOPI) THEN
position(i) = TWOPI - 1E-6
END IF
END DO
Can you please let me know ifthere is anythingto be changed here?
Thanks in advance.
Sasidhar
jimdempseyatthecove
Sasidhar,
Is position real(4) or real(8)?
is TWOPI real(4) or real(8)?
If TWOPI = 3.14159..., is 3.14159... a single precisionor double precision constant? (Match the literal type with the variable type as constants are not promoted)
1E-6 is single precision. Subtracting a 1E-6 from a 3E+0 will require 7 digits of precision which are not available in single precision.
If position and TWOPI are real(8) then use 1D-6 for the literal or perhapse you are looking for
position(i) = TWOPI- TINY(TWOPI)
This will produce the largest number less than TWOPI representable in the precision of what is used for TWOPI. (Hopefully position is the same precision as TWOPI).
Jim Dempsey
