29642 Discussions
Intel License Server for Windows Link
fohfab
This maybe a Fortran issue, but since transfering my C and Fortran projects over to Visual Studio 2010 and upgrading to Intel Composer XE 2011, I have found the the compilation/composing perfomance of Fortran projects is very slow. The compilation of C code is fine.
The machine is a Windows Server 2008 with dual core and looking at the Windows Task Manager, I can see the the two cores are inactive for about 28 seconds out of 30! This seems to tie in with starting to compose a new source file in the project.
The memory usage is constant, but the CPU remians at 0% for 90% of the time.
I am suspecting this might be a licenseing issue and I have found an article relating to using the Composer on Windows Server 2008. The article suggests downloading the Windows License Server and starting this manually, but I have spent the last hour looking for a link to download this product without success. Where can I get this from, and do you think this might solve my problem?
Anonymous66
Valued Contributor I
Hello fohfab,
What was the compilation performance like before you upgraded?
If you have any evaluation licenses, one thing I would suggest doing is moving them out of the license folder.
Annalee
