29560 Discussions
Intel MPI Fortran & Intel C++ Coupling Error
Yamaguchi__Alan
Hello, I am trying to compile a simple just to check mpi fortran is working well with C++ but for some reason, I keep getting compiling errors or an executable which gives segmentation fault.
Environment:
  • CentOS 6.7
  • ifort (IFORT) 19.0.1.144 20181018
  • GCC 4.4.7
  • Not using openmp
testf.f
      PROGRAM hello
      include 'mpif.h'
      integer :: PETOT, my_rank, ierr
      integer :: af, bf, cf
      CALL MPI_INIT (ierr)
      CALL MPI_COMM_SIZE (MPI_COMM_WORLD, PETOT, ierr)
      CALL MPI_COMM_RANK (MPI_COMM_WORLD, my_rank, ierr)
      write(*,'(a,2i8)') 'Hello World Fortran', my_rank, PETOT
      CALL MPI_FINALIZE (ierr)
      af=2
      bf=3
      CALL runc(af,bf,cf)
      write(*,*) cf
      STOP
      END
testc.cc
#include <stdio.h>
extern "C" {
      int runc_(int &a, int &b, int&c);
int runc_(int &a, int &b, int&c) {
      c=a+b;
      printf("Hello world\n");
      return 0;
At first I tried using GCC instead of icpc and everything went well with the compiling and execution.
mpiifort  -c -fpp testf.f -o testf.o
gcc -c -W -Wall testc.cc -o testc.o
mpiifort  testf.o testc.o  -fpp -o test.exe
However when I tried to use icpc using the exact same commands I get this error: testc.o:(.eh_frame+0x11): undefined reference to `__gxx_personality_v0'
By the end I managed to compile it with this sequence of commands only to get a segmentation fault at the executable.
mpiifort -c -fpp -shared -fpic testf.f -o testf.o
icpc -c -W -Wall -shared -fpic testc.cc  -o testc.o
mpiifort  testf.o testc.o -fpp -shared -fpic -o test.exe
I really appreciate any kind of help here. Pretty much my first time compiling fortran/c++ together and cannot understand why there is this error with icpc but not with gcc (library linking problem?). Thanks in advance.
jimdempseyatthecove
RE: gcc link
From one of the other forums:
You're probably using gcc for linking c++ code. Change it to g++ and it will work.
I cannot test this here...
RE: Segfault
Assure that you properly sourced both the ifort and intel MPI environments.
Jim Dempsey
