29390 Discussions
Intel OneAPI cannot read from a long line properly on Windows 10?
CRquantum
I have a code test.exe and simply need to read the variables from a file called nuclear.dat, like below
mpiexec -n 6 test.exe < nuclear.dat
However it just hangs there. This issue seem only occur with Intel OneAPI and on Windows. The newest OneAPI 2023 version still have this issue.
But if I just do
then it correctly output the results.
Below is the input file called nuclear.dat,
9002785287  # * irn. boss random number seed
12          # imode. 11 mean V fixed. 12 means full mixing, both V and k are flexable. CHoose 12 for now.
1000        # * itermax. max iteration number. Usually with stopping criterion code should stop before itermax.
.true.      # * stop_criterion_on. Enabling stop criterion or not. .true. means yes enable.
30          # * LL_n. The number of continuous iterations for averaged slope. and then calculating the averaged parameters. currently just use this one number.
0.0         # * crit_1. The value of slope for stop criterion. The iteration begin 'smoothing' stage after averaged slope smaller than this value. Set to zero.
1           # * kmix. The gaussian mixing number.
.true.      # read Yji or generate Yji. Currently set it as .true.
1000        # * mgauss_all. number of gaussian samples in E step.
5000000     # * m_all. Metropolos samples in M step.
30          # * i_init. This is for initial condition. Currently it is from 1 to 50 which is the number of subjects. Select the subject from simpar to start initial condition
simdata.csv     # data.csv name
simpar.csv      # parcsvname
The program is,
program main
use mympi
integer, parameter :: i4=selected_int_kind(9)
integer, parameter :: i8=selected_int_kind(15)
integer, parameter :: r8=selected_real_kind(15,9)
integer(kind=i8) :: irn,imode,itermax,kmix,mgauss_all,m_all,i_init
integer :: LL_n
logical :: stop_criterion_on,readYji
real(kind=r8) :: crit_1
character(len=50) :: csvname != 'simdata.csv'
character(len=50) :: parcsvname ! = 'simpar.csv'
call init0 !mpi initialization must be done before reading
  if (myrank()==0) then
    read (5,*) irn
    read (5,*) imode
    read (5,*) itermax
    read (5,*) stop_criterion_on
    read (5,*) LL_n
    read (5,*) crit_1
    read (5,*) kmix
    read (5,*) readYji
    read (5,*) mgauss_all
    read (5,*) m_all
    read (5,*) i_init
		read (5,'(a50)') csvname
    read (5,'(a50)') parcsvname
    csvname = adjustl(csvname)
    csvname = csvname(1:index(csvname,' ')-1) ! there should be space before # in the input file.
    parcsvname = adjustl(parcsvname)
    parcsvname = parcsvname(1:index(parcsvname,' ')-1)
    write (6,'(''Boss random number seed ='',t30,i20)') irn
    write (6,'(''imode ='',t30,i20)') imode
    write (6,'(''iteration max # ='',t30,i20)') itermax
    write (6,'(''Stop Criterion (SC) on ='',t40,l10)') stop_criterion_on
    write (6,'(''SC # of averaged iterations ='',t30,i20)') LL_n
    write (6,'(''SC stopping slope <'',t40,f10.5)') crit_1
    write (6,'(''Mixing number ='',t30,i20)') kmix
    write (6,'(''Read Yji ='',t40,l10)') readYji
    write (6,'(''# Gauss samples for E step ='',t30,i20)') mgauss_all
    write (6,'(''# Metropolis samples for M step ='',t30,i20)') m_all
    write (6,'(''Initially from subject # '',t30,i20)') i_init
    write (6,'(''data.csv file name ='',t30,a30)') csvname
    write (6,'(''simpar.csv file name ='',t30,a30)') parcsvname
endif
end
My MPI module is
module mympi
use mpi
implicit none
integer, private, parameter :: i4=selected_int_kind(9)
integer, private, parameter :: i8=selected_int_kind(15)
integer, private, parameter :: r8=selected_real_kind(15,9)
integer, private, save :: mpii4,mpii8,mpir8
integer(kind=i4), private, save :: irank,iproc
contains
subroutine init0 ! call this before anything else
integer :: ierror,isize,ir,ip
integer(kind=i4) :: itest4
integer(kind=i8) :: itest8
real(kind=r8) :: rtest8
call mpi_init(ierror)
call mpi_comm_rank(mpi_comm_world,ir,ierror)
irank=ir
call mpi_comm_size(mpi_comm_world,ip,ierror)
iproc=ip
call mpi_sizeof(itest4,isize,ierror)
call mpi_type_match_size(mpi_typeclass_integer,isize,mpii4,ierror)
call mpi_sizeof(itest8,isize,ierror)
call mpi_type_match_size(mpi_typeclass_integer,isize,mpii8,ierror)
call mpi_sizeof(rtest8,isize,ierror)
call mpi_type_match_size(mpi_typeclass_real,isize,mpir8,ierror)
return
end subroutine init0
subroutine done ! wrapper for finalize routine
integer :: ierror
call mpi_finalize(ierror)
return
end subroutine done
function myrank() ! which process am I?
integer(kind=i4) :: myrank
myrank=irank
return
end function myrank
end module mympi
The whole solution file has been attached.
Could Intel please check this? Thanks much!
Ron_Green
Let's review
You run the code without MPI
   doesn't this imply there is no problem with your code and the compiler?
With 6 MPI ranks it "hangs"
So what happens when you run 1 rank with mpiexec -n 1 ?  That should be the first test.
I suspect your "hang" is that 6 copies of your program is exceeding the #cpus you have and/or the amount of RAM in your PC.   Do you have 6 physical CPUs which will show up in WIndows as 12 "Processors" due to hyperthreading.
How much memory is needed for each instance of the program?  Run memory monitoring and then launch 1, 2, 3 copies of your program.  Are you exceeding your RAM?
Here's is how you can check your PC’s system resource usage with Task Manager.
  1. Press CTRL + Shift + Esc to open Task Manager.
  2. Click the Performance tab. This tab displays your system's RAM, CPU, GPU, and disk usage, along with network info.
  3. To view RAM usage, select the Memory box. That box provides info for how much RAM is in use and how much remains available.
CRquantum
Hi Ron,
Thanks for the reply.
This minimal working example (MWE) code is extremely simple. As you can see, rank 0 read the variables from nuclear.dat, then write the variable values on the screen, that is all. I have also attached the whole VS sln file, everything is included. So I believe it is easy for you to reproduce this issue.
What you said is great to start, I appreciate it, but it is not the problem.
mpiexec -n XXX test.exe < nuclear.dat
No matter XXX is, 1 or >1, it just hangs.
It only cosumes 1.4MB on each of cpu core. My laptops all have >= 6 cores (so >= 12 threads).
However, without mpiexec, it works as expected,
The output should be,
The strange thing only happens on Windows, and I use the latest version OneAPI 2023.0. Older versions of OneAPI on windows has the same problem.
Now, if you remove all the comments (you know those start with #) in the nuclear.dat, it works.
But I do not understand why with those comments in the nuclear.dat, it just hangs. However on Linux it works fine as always.
In fact, it is exactly because of this issue, I decided to use a namelist file instead of the nuclear.dat, as suggested by urbanjost,
https://fortran-lang.discourse.group/t/intel-fortran-cannot-read-from-a-long-line-properly/2933/5
however namelist has issue too, but has been solved by James and Barbara,
https://community.intel.com/t5/Intel-Fortran-Compiler/Cannot-read-namelist-when-using-MPI-with-OneAPI-in-Windows-10/m-p/1460503#M165326
I may try putting things in a namelist file than the nuclear.dat.
Barbara_P_Intel
According to James, the batch file workaround behaves properly for this case. I am escalating this to our MPI team to work on.
CRquantum
Thank you Barbara, hopefully this issue on Windows may be solved.
TobiasK
Hi @CRquantum
sorry for the long silence, could you please double check if your files contain a new empty line at the end? I can trigger this bug only if I have no new line at the end of the file, regardless of the length.
jimdempseyatthecove
What happens if you trace the reads?
    print *,"read (5,*) irn"
    read (5,*) irn
    print *,"irn=",irn
As a work around, read the line into a large character variable, search for "#", if found, kill from there to end of line, then use internal read to convert from text to number. (Include the trace of the activity).
If that fails, then instead of using "< nuclear.dat" use "nuclear.dat" , use GET_COMMAND_ARGUMENT to fetch the file name, and then open the file for reading.
Jim Dempsey
