29652 Discussions
Intel Parallel Debugger Extension Exception?
abhimodak
Hi
I am doing a debug build and then running a program. This runs successfully and produces correct answer; but in the output window I see the output as shown below. I am wondering what is the stuff in bold telling me.
I had experimented with compiler switch /Qparallel but then I had removed it, cleaned the object files, and rebuilt the project.
Sincerely
Abhi
p.s. I am not sure if this information is enough. If not, what else would be needed to make some sense? One more thing: Earlier we used libguide.dll but now we are usin libguide40.dll (as can be seen in the output below).
'program.exe': Loaded 'C:\\Abhi\\myVSS\\bin\\program.exe', Symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\ntdll.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\kernel32.dll', No symbols loaded.
'program.exe': Loaded 'C:\\Abhi\\myVSS\\bin\\programdll.dll', Symbols loaded.
'program.exe': Loaded 'C:\\Program Files (x86)\\Intel\\Compiler\\11.1\\054\\lib\\intel64\\libguide40.dll', Binary was not built with debug information.
'program.exe': Loaded 'C:\\Abhi\\myVSS\\bin\\erg.dll', Binary was not built with debug information.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\advapi32.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\rpcrt4.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\secur32.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\user32.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\gdi32.dll', No symbols loaded.
'program.exe': Loaded 'C:\\Abhi\\myVSS\\bin\\zd.dll', Binary was not built with debug information.
'program.exe': Loaded 'C:\\Abhi\\myVSS\\bin\\uzd.dll', Binary was not built with debug information.
'program.exe': Loaded 'C:\\Abhi\\myVSS\\bin\\sm.dll', Symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\wsock32.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\msvcrt.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\ws2_32.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\ws2help.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\netapi32.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\comdlg32.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\shlwapi.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\WinSxS\\amd64_Microsoft.Windows.Common-Controls_6595b64144ccf1df_5.82.3790.3959_x-ww_AB06DEB0\\comctl32.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\shell32.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\imagehlp.dll', No symbols loaded.
First-chance exception at 0x77d4dd10 in program.exe: 0xA1A01DB1: Intel Parallel Debugger Extension Exception 1.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\imm32.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\WinSxS\\amd64_Microsoft.Windows.Common-Controls_6595b64144ccf1df_6.0.3790.3959_x-ww_0A7B2435\\comctl32.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\iphlpapi.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\psapi.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\icmp.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\mswsock.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\dnsapi.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\winrnr.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\wldap32.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\uxtheme.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\rasadhlp.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\hnetcfg.dll', No symbols loaded.
'program.exe': Loaded 'C:\\WINDOWS\\system32\\wshtcpip.dll', No symbols loaded.
The thread 'Win64 Thread' (0x2084) has exited with code 0 (0x0).
The thread 'Win64 Thread' (0x2a30) has exited with code 0 (0x0).
The thread 'Win64 Thread' (0x2b78) has exited with code 0 (0x0).
First-chance exception at 0x77d4dd10 in program.exe: 0xA1A01DB2: Intel Parallel Debugger Extension Exception 2.
The program '[10660] program.exe: Native' has exited with code 0 (0x0).
Did you follow the instructions in the compiler release notes for setting up how these exceptions are handled in VS2005? They are used internally by the parallel debugger extension and in VS2005.
