29643 Discussions
Intel Parallel Studio XE 2015 Composer Edition Intel(R) 64 Visual Studio 2013
abhi_b_
Dear Sir/Madam,
Can someone please help me with this question:
I have installed a 30 day trial version of Visual Studio 2013 to run Fortran; however, I can compile and run codes with IA-32 but not with Intel(R) 64. I get the following error:
A licence for FCompW is not available.
I have been directed to the support site for help.
The associated problem being that I am unable to run ABAQUS with user subroutine (FORTRAN).
Do I have to buy the product to be able to use Intel(R) 64?
That's unusual. No, you should be able to use Intel 64 for a trial. Try rebooting Windows to see if that clears it. I haven't heard of this problem before - let us know what happens and if it's still not working let us know.
abhi_b_
Dear Steve,
I rebotted the computer; however, I am getting the same error message. I have attached a jpeg file showing the error in 64 as opposed to 32. Thank you for responding to my question.
Abhi,
I will send you a license file tomorrow and instructions on what to do with it.
Radwan_H_
Hello There,
I downloaded a 30-day trial version of Intel Parallel Studio XE 2015, and I am getting a licensing error when trying to run ifort.  the Intel Software manger shows that I have 10 licenses.
C:\Program Files (x86)\Intel\Composer XE 2015\bin\intel64>ifort
Error: A license for FCompW is not available (-158,61003,2).
License file(s) used were (in this order):
    1.  Trusted Storage
    2.  C:\Program Files (x86)\Common Files\\Intel\Licenses\*.lic
    3.  C:\Program Files (x86)\Common Files\Intel\Licenses\*.lic
    4.  C:\Program Files\Common Files\Intel\Licenses
    5.  C:\PROGRA~2\Intel\COMPOS~1\bin\intel64\*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
ifort: error #10052: could not checkout FLEXlm license
I would appreciate your help
Radwan, I will check with my team on Monday about this problem, as it appears to be affecting multiple users.
If you're having this problem - being able to compile for IA-32 but not for Intel 64 with an evaluation license, please do the following:
Click on the Start button and in the search box, type services.msc . When that appears in the results, click on it to open.
Scroll down the list of services. You should see two entries, "FlexNet Licensing Service" and "FlexNet Licensing Service 64". Click on "FlexNet Licensing Service 64" - in the upper left of the Services panel should be a link to "Start the service". Click on that link.
Can you now compile? If so, right click on the service name and select Properties. Change Startup Type to Automatic and click OK.
This should not be necessary, but it may help you until you have a purchased license. Let me know if it helps or if you get any error messages when starting the service.
abhi_b_
Dear Steve,
Reinstalling Fortran with the new serial number worked. Thank you so much for your help.
Abhi, glad to hear it. Radwan, let me know if the suggestion above works for you. If not, I'll send you a serial number too.
We have reproduced the problem and will get it fixed for a future update. Radwan, I will send you a serial number to use for the install - this is a workaround.
alvaro_d_
Dear Steve,
I have the same license problem on a simple "hello world' program.
>  ***** ClCompile (x64 - Intel C++)
1>
1>  Error: A license for CCompW is not available (-158,61003,2).
1>
1>  License file(s) used were (in this order):
1>      1.  Trusted Storage
1>      2.  C:\Program Files (x86)\Common Files\\Intel\Licenses\*.lic
1>      3.  C:\Program Files (x86)\Common Files\Intel\Licenses\*.lic
1>      4.  C:\Program Files\Common Files\Intel\Licenses
1>      5.  C:\PROGRA~2\Intel\COMPOS~1\bin\Intel64\*.lic
1>
1>  Please visit http://software.intel.com/sites/support/ if you require technical assistance.
1>
1>icl: : error #10052: could not checkout FLEXlm license
I modified the service as you mentioned above But it does not worl
"Click on the Start button and in the search box, type services.msc . When that appears in the results, click on it to open.
Regarding the license, i downloaded yesterday night (Paris, France ) the parallel_studio_xe_2015 and installed it today.
Very Best Regards
PS: I noticed that i can compile and linked the same simple "hello world" program in win32 but not in x64.
Alvaro, I will send you a private message with a serial number to use. Uninstall Fortran and then reinstall using the serial number.
Unfortunately, our license system is down right now. I will try again tomorrow.
Ok, serial number sent.
alvaro_d_
Thank  you,
I received the serial number and installed the software. Unfortunately,  the result is the same failure.
Actually i installed an update related to the fortran compiler. But in my case, i use "microsoft visual studio" for the C++.
The error i get is :
--------------> Error: A license for CCompW is not available (-5,357).
Make sure that a license file is being used that contains a license
1>  for the requested feature.  If your license requires a license server,
1>  make sure that the server is using the right license file (usually,
1>  this would be the same license file that is being used by this
1>  application), and make sure that you have not changed the license
1>  file since starting the server.
1>
1>      2.  C:\Program Files (x86)\Common Files\\Intel\Licenses\w_RXN8DVPH.lic
1>      3.  C:\Program Files\Common Files\Intel\Licenses
1>      4.  C:\PROGRA~2\Intel\COMPOS~1\bin\Intel64\*.lic
-------------->icl: : error #10052: could not checkout FLEXlm license
2 Flex services were launched : "flexnet Licensing services" and "Flexnet licensing 64"
Best Regards
I sent you a Fortran license by mistake. I will send you a C++ license.
alvaro_d_
It works!!!
many thanks
Clare_F_
I am having the same problem - I've downloaded the 30-day trial fortran compiler and am getting the same error "A license for FCompW is not available". I've tried your suggestions above (restarting the FlexNet Licensing Service 64, rebooting) with no success. Any help would be appreciated.
Clare
What I've been told is an easy workaround is to use the Fortran Build Environment Command Prompt for Intel 64 shortcut, but right clicking on it and selecting "Start as Administrator". Then type "ifort" at the command prompt. You should need to do this only once.
Clare_F_
That worked - thanks!
TimP
I always do this anyway, so as to make a permanent change in edit options, font, and layout.
