29594 Discussions
Intel Parallel Studio XE 2016 has been released!
Intel Parallel Studio XE 2016, including Intel Visual Fortran Compiler 16.0, is now available. If your support license is current you can download and install this at no additional charge from the Intel Registration Center
Licensing Changes
With the 2016 version of our products, we are enforcing a limit of three installs per named-user license. If you have been a user of earlier versions, you'll need to upgrade the license file on your system in order to use the 2016 versions. (Earlier product versions will work with the new license.) The simplest way to do this is to reenter your serial number when prompted during install, but there are other options. Please refer to the following articles for more information:
If you need help with licensing, please ask in our Licensing, Registration and Downloads forum or Intel Premier Support
Microsoft Visual Studio 2015 Information
If you have installed Microsoft Visual Studio 2015 (VS2015), be aware that the default VS2015 installation does not include C++ support, which means that Intel Visual Fortran integration won't install. If you are installing VS2015 new, select Customize and check the box for Visual C++ (see image below). Otherwise, do a Modify of VS2015 and make sure the Visual C++box is checked.
If you don't have a supported Visual Studio installed (VS2010, 2012, 2013, 2015), a Fortran-only development environment based on VS2013 will be installed. However, this requires that the Microsoft Windows SDK for Windows 8.1 be installed, and Microsoft requires us to have you get that from them directly. Please see Install Windows SDK for VS2013 Shell for more details.
Gerdes_Gerhard_J
This comment has been moved to its own thread
ZX_L_
Dear Steve Lionel ,
   I have intalled Intel Parallel Studio XE 2016 cluster edition with all components for Fortan, it's a trial version.
   My Windows version is 8.1. After I had installed  visual studio 2015 (community 2015), and then Intel Parallel Studio XE 2016 cluster edition including all components for Fortan, I have initialized the Intel Parallel Studio XE tools by running psxevars.bat in the directory of C:\Program Files (x86)\IntelSWTools \parallel_studio_xe_2016.0.041\bin
and set the environment settings: in the directory of C:\Program Files (x86)\IntelSWTools \mpi\ 5.1.1.110\intel64\bin, by using the call batch command to run the mpivars.bat batch for the architecture. The Intel MPI Library installation directory is C:\Program Files (x86)\IntelSWTools.
     I can compile and run my programme with sequential architecture successfully, but I don't know how to compile and run a programme with parallel architecture.
      I want to get your help. Thank you very much.
        Yours sincerely
       Z.X. Li
Walt_Brainerd
hans1
Lars_H_
