29433 Discussions
Intel® Parallel Studio XE Composer Edition18.0 for Fortran macOS* in Xcode9.4.1
Wong__Break
Hi all
Intel® Parallel Studio XE Composer Edition for Fortran macOS* 18.0 (Student) & Xcode9.4.1 had installed.
Question is I can not find Intel® Fortran Compiler in Using Option when Build Rules.
Refer to intel® Fortran Compiler 18.0 Developer Guide and Reference, reinstalled the compiler (step a) and It does not work to change directory to the installation directory for the intel® Compiler IDE integration (step b) : cd  /Library/Application\ Support/Developer/, no such file or directory shows in terminal window.
Someone help,
Best regards
Juergen_R_R
Valued Contributor II
I'm a bit lost what the exact question is: you cannot find how to install the ifort Fortran Compiler, or you cannot afterwards find the ifort executable, or you cannot find an IDE?
Wong__Break
It's really hard to say, cause the question I just can't define. I wanna compile Fortran in Xcode. But now, When i create a new Xcode project, choose Command line tool in Application, then Build Rules for Process: Fortran source files, and I just can't find Intel® Fortran Compiler in using option
Juergen_R_R
Ok, I cannot help you with that. I do software development under MACOSX, but in the console, I don't use XCode.
Wong__Break
Thanks anyway
Barbara_P_Intel
According to the release notes, macOS 10.13 and Xcode 9.3 are supported with Intel Fortran Compiler 18.0.3..
Here's a link to the release notes, https://software.intel.com/en-us/articles/intel-fortran-compiler-180-for-macos-release-notes-for-intel-parallel-studio-xe-2018. Earlier versions of the compiler work with earlier versions of macOS and Xcode.  Details are in the release notes.
Wong__Break
It doesn't work well in Xcode 9.4. Now I have no idea about what happened and what I should do...
Wong__Break
Hey  guys
The problem above has already solved by version:2019 perfectly
Thanks ALL
