29560 Discussions
Intel® Parallel Studio XE2015 Composer Edition, download
biswas__kamanasish
I need Intel Parallel Studio XE 2015 Composer Edition (Windows as well as Linux Version), to link with Abaqus 6.14.
I am unable to locate the XE 2015 version (Student). Can anyone suggest how can i get this version?
Also is this the only compatible version with Abaqus 6.14?
Kamanasish
Steve_Lionel
Use the latest version. It should work fine With Abaqus. At most you may need to edit the script Abaqus uses to find the compiler, updating any use of an INTEL_COMPILERxx environment variable to use INTEL_COMPILER20 for the latest one.
Student licenses do not have access to very old and obsolete compiler versions.
biswas__kamanasish
Thanks Steve, I'll try with the latest version. However, as per few document available online,  i see Abaqus is compatible with Parallel studio XE composer edition, and what i can download is, a Cluster version. Do you think it'll work?
kamanasish
Steve_Lionel
Yes - the Cluster Edition just contains more tools (that you won't use here.)
