29607 Discussions
Intel (R) Visual Fortran compiler XE 19.0.0.117 - 64 bits
theyohan258
Hello, I hope you are all well, I need a favor people and it is how to find this compiler (Intel (R) Visual Fortran compiler XE 19.0.0.117 - 64 bits) to install it since I can't find it anywhere and I need it to run a program made in this version, or if someone knows how to do it.
JohnNichols
Honored Contributor I
You can compile the program in the latest version of oneapi and it should run.  It is difficult to get old compilers unless you are a paid supporter, is my understanding.
There is little standard code written that will not compile in the new compiler.
theyohan258
i need a old version, because the proyect no compil, i want use in PSCAD
