29652 Discussions
Intel Visual Fortran Compiler Version 9.1
niall_osullivan
We have recently purchased the current version of the Intel Visual Fortran Compiler but due to the software that it will be used with, ie PSSE 31, an earlier version is required, this version being v9.1. Our local suppliers have indicated that once the current version has been purchased an earlier version can also be obtained.
Please explain how Intel Visual Fortran Compiler v9.1 may be obtained.
Niall O'Sullivan
HMRC, UCC
ArturGuzik
Valued Contributor I
Quoting - niall_osullivan
Niall O'Sullivan
HMRC, UCC
See this info.
A.
niall_osullivan
Quoting - ArturGuzik
See this info.
A.
Artur,
Thank you for your response.
When I click on the link that you supplied and follow the subsequent links to the get an older version of an Intel Software Development Product, the version that I require is not listed among the products that are available to me, versions 10.1 to 11.1 are all that are listed, see attached file.
Please explain how the Intel Visual Fortran Compiler v9.1 may be obtained?
Niall O'Sullivan
Open the article Artur pointed to, read item #1 in the list and follow the link there.
niall_osullivan
Steve,
As explained in my previous message when I follow Artur's link the version of the Fortran compiler that I require is not listed among "My Intel Software Development Products" nor does it seem to be available on the premier support page, ie https://premier.intel.com/ .
Please explain where the Intel Visual Compiler v9.1 can be obtained or alternatively confirm that it is no longer available.
Niall O'Sullivan
HMRC, UCC
ArturGuzik
Steve,
Niall O'Sullivan
HMRC, UCC
Niall,
the link leads you to this (more appropriate one).
If you try to follow it, the crucial steps are 3 and 4. That is:
Choose the component of interest or click on the More Info link. You will be presented with a drop down list of release versions for the selected product.
You need to click on the product link (not on download the latest) and THEN on the next page you'll have a version (combo) selection. The version 9.0 is available (I see even ver 8.0)
A.
Edit: On you screenshot (previous post) -- click the highlighted (blue) in Product Information (the leftmost column).
niall_osullivan
Niall,
A.
Artur,
I have finally located and downloaded the required version of the compiler. The postscript that you added to your message finally pointed me in the right direction.
Thank you for your help and patience.
Niall O'Sullivan
