29640 Discussions
Intel Visual Fortran Composer XE 2011 code 1 Error
mcsebubba
I'm trying the new Fortran compiler. One of my subroutines gets an error code 1 and says I need to file a Software Problem Report. How does one do that?
Wendy_Doerner__Intel
Valued Contributor I
You can either post a test case here in the forum (I can make the thread private so only you andIntel can see it) or you can file an issue at premier.intel.com. You can get your premier account when you register your product at registrationcenter.intel.com.
Wendy
Attaching or including files in a post
