Intel Visual and PGI Visual
Ted_Lillys
I have need to use both of these compilers (legacy issues). I'm in the process of setting up a new development machine.  I currently have Parallel Studio XE 2017 Update 2 and PGI 15.10.  Will these play nicely under one version of Visual Studio or do they need to be separated?
TIA
Ted
Steve_Lionel
You'll almost certainly need to use separate VS installs for these, at least inside Visual Studio. If you're using the command line only, it should work ok.
