29542 Discussions
Intel oneAPI fail to install VS22 on Win11 & Parallels Studio on M4-series chip
TiborKibedi1
I try to install Intel oneAPI and Intel HPC toolkits on a Windows 11 (64-bit operating system, ARM-based processor) Virtual Machine, using Parallels Studio. The host is an Apple MacBook with M4 chip. The installation of Visual Studio 2022 Community edition was successful, however the installation of oneAPI base toolkit fails. The log file reports the following error:
Attempt 2 of 2 failed. Execution of C:\Program Files (x86)\Microsoft Visual Studio\Installer\resources\app\ServiceHub\Services\Microsoft.VisualStudio.Setup.Service\VSIXInstaller.exe failed with exit code 2003, output:
Error: Failed to complete session ID.
11/10/2025 06:25:09:356 : 5440 : MESSAGE : Operation 'complete.operation.intel.sessionmanifest.1762715653790454' execution is finished with status SuccessWithFail.
11/10/2025 06:25:09:356 : 5440 : MESSAGE : Starting execution of operation 'update_state.operation.intel.sessionmanifest.1762715653790454'.
11/10/2025 06:25:09:366 : 5440 : MESSAGE : Operation 'update_state.operation.intel.sessionmanifest.1762715653790454' execution is finished with status Success.
11/10/2025 06:25:09:366 : 5440 : ERROR : Install sequence execution status: SuccessWithFail
 I am using the latest versions of Win11, VS2022 and oneAPI. The full logfile is attached.
Any insight or comment would be very useful.
Steve_Lionel
This does not astonish me, as the Intel compiler wants to see an X86 (X64, really) processor, not ARM. Visual Studio does support ARM processors.
TiborKibedi1
Thanks Steve the explanation. It is further restriction of code developments on different platforms.
GeorgiosAnagnostou
Dear Tibor - I have exactly the same problem. I wonder if and how you solved that.
Dear Steve - any help greatly appreciated.
Mark_Lewy
Valued Contributor I
It was Apple's decision to change processor architecture to ARM 64 that means that the Intel compilers no longer support it.  You wouldn't expect Intel to produce a compiler for a competing architecture.
Also, Microsoft have discontinued VS for Mac.
You will have to use an alternative compiler and IDE - see Setting up your OS — Fortran Programming Language
GeorgiosAnagnostou
Thank you Mark. In the meantime I found an excellent alternative which works perfectly for me: an Azure virtual machine with my mac as a frotend.
