29487 Discussions
Intel(r) Visual fortran run-time error
Islam__Shahidul
I am getting the following error message while performing sediment transport simulation in SMS software. Is there any solution to this problem?
mecej4
The problem arose because the data file that your program read from was not matched with the READ statements for the file. Check (i) that the file was opened properly, with STATUS='OLD', and (ii) check that the data file contains enough data to supply all the READ statements, or that some of the READ statements contains END= or IOSTAT= clauses based on which proper action is taken.
