29650 Discussions
Interface wanted for SetDCPenColor
anthonyrichards
New Contributor III
I want to use windows API function SetDCPenColor.
Can anyone supply an Interface block for it?
It is not in GDI32.F90, where I expected it to be.
thanks in advance
Jugoslav_Dujic
Valued Contributor II
interface
integer(ULONG) function SetDCPenColor(hDC, crColor)
!DEC$ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:
'SetDCPenColor':: SetDCPenColor
use DFWINTY
integer(HANDLE):: hDC
integer(ULONG):: crColor
end function
end interface
Be aware -- Win2000 or newer only.
Jugoslav
anthonyrichards
New Contributor III
Thanks, Jugoslav. I'll let you know how it goes after the holiday.
anthonyrichards
New Contributor III
It worked fine, Jugoslav, thanks again.
DC_PEN and DC_BRUSH are defined in DFWINTY, with vales 19 and 18.
